Problem on "summary" block
- Meteofabro
- Software: Meteobridge RED PRO
hello.
I wanted to point out that on the "summary" block the forecast no longer works (if I remember correctly it was weekly) which I believe was taken from Dark Sky.
Has anyone solved the problem yet?
- 2022-06-27 15_16_16-MeteoFabro_previsione.png (58.57 KiB) Viewed 34298 times
Re: Problem on "summary" block
Is in my 'todo' list ( if I remember correctly is derived from yr.no and hast to be updated to his v2 api )
- Meteofabro
Updated the block.
v5.5
- forecasts: updated to yr.no api v2.0
v5.6
- forecasts: corrected temperature import
v5.7
- forecasts: corrected day capitalization ( en, us, de languages )
Api v2.0 does not contain the wind name, so it will not appear in forecast
v5.5
v5.6
v5.7
- summary_5.7.zip
- (109.83 KiB) Downloaded 847 times
- summary_5.6.zip
- (115.14 KiB) Downloaded 788 times
- summary_5.5.zip
- (109.9 KiB) Downloaded 1063 times
- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
Hello David
I have a problem with the temperature display (see image)
and thank you again for your work
- summary.jpg (149.91 KiB) Viewed 34185 times
I agree... 1027°C is too much even for global warming ; - )
Added updated version to previous post.
- Jolumarali
- Software: WlIP
Hello Davide
update done, correct temperature, no worries
thanks again
thanks again
- Meteofabro
- Meteofabro
Hello Davidefa.
By adding the "Summary" block to the smartphone / mobile version of the meteotemplate, you have a strange formatting, causing the block to move the graphics of all the blocks beyond the right edge of the smartphone display, so they do not remain centered.
Is it possible to solve this problem?
This occurs only by adding the "Summary" block to the meteotemplate for mobile devices.
Thank you.
Thank you.
- Screenshot_2022-07-23-13-41-57-975_com.android.chrome.jpg (570.39 KiB) Viewed 34085 times
- Meteofabro
I have changed the menus of the block, they seem more appropriate to me. But I still haven't fixed the formatting of the menu items.
Example are the entries "Week", "Station" and "Tomorrow" are without separator space.
How can I solve the problem?
- Screenshot_2022-07-23-14-34-26-406_com.android.chrome.jpg (1015.85 KiB) Viewed 34081 times
Sorry forgot to check your question:
solution a) rotate your phone ( sorry, this is my preferred solution as I have to do nothing ; - )
solution b) we can arrange the 'selection tabs' as a 'drop down menu' ( as the key factor is the length of these tabs )
solution c) we have to define 'super short' tabs headings ( shorter than you did ex: "Oggi Ora, Set. Staz. Dom. Altro" ), not very clear in my opinion, but easy to do
