Time format import
Remkot
Station model: Ws-5500
Software: Wu
Time format import
Post by Remkot » Thu Jul 21, 2022 8:30 am
Hello all,
I want to transfer some data from weathercloud to meteotemplate. (because weatherunderground is no longer possible I read.)
When I import the csv file and test it I get the message "There seems to be a problem with the date and time."
https://weerstationoosterbeek.nl/2.csv
I think I have the date and time format wrong. Can someone tell me what the right format is?
thank you very much.
Remko
Re: Time format import
Post by davidefa » Thu Jul 21, 2022 8:01 pm
- converted the file to ansi format ( think it was a 2 byte unicode )
- removed the '.' as separator for thousands
You can import with the following settings:
NOTE ( not super important )
It is better to have an uniform 'database recording interval' ( to prevent a few 'hiccups' in blocks/pages, for example you could end up having two different, although similar, results for the same calculation in two different blocks/pages ).
If your 'database recording interval' is the default 5 minutes, also your imported data should be 'spaced' by 5 minutes.
As your csv file has a data interval of 10 minutes, I created a second copy with time shifted by 5 minutes, import both files and you should be good to go.
2.zip
(72.64 KiB) Downloaded 876 times
Remkot
Software: Wu
Post by Remkot » Sat Jul 23, 2022 8:39 am
thank you very much for the explanation. It finally worked! Thank you!
