Hi....
I'm new to Meteotemplate, and like what I see so far. There are a few things that I am struggling with though. One of those is the transition to PHP 8.0. I am currently running PHP 7.4, which is fine. I have found though that there is an API.PHP update which has better support for my Ecowitt GW1000, but it only functions with PHP 8.0. I have found other updates also, such as easy installation for blocks and plug-ins, some of which also require PHP 8.0.
Part of my struggle is trying to find ALL the updated/fixed blocks and plug-ins. They seem to be scattered about in different posts, and it requires a great effort to locate them.
Are there any plans to create some sort of repository so that updates/fixes are in a central location? It would greatly simplify the task of building and maintaining a Meteotemplate website.
User DAVIDEFA has a GitHub site I have found, which is quite helpful.... Thank you David!
rabrand1955
Where can I find ALL updated/fixed code?
rabrand1955
- Station model: Ambient Weather WS-2000
Julius
- Station model: Barani MeteoHelix
- Software: meteobridge
Re: Where can I find ALL updated/fixed code?
I agree, patches/updates to the core seem to be very rare, but those that are there are not available through the supposed channels. I have many blocks that are running a newer version than the one that is available in the Blocks download section. Gets really confusing over time..
Agreed, the forum is not the simplest way to organize ( and even search ) informations.
You may try the 'ultimate mod' a simple extension to install blocks/plugins/mods published in this forum, as done with the official ones.
The php 8.0 update I published should be compatible even with php 7.4 ( at least I check on my php 7.4 test server )
- Station model: Ecowitt WS90
It works, but some blocks are still broken migrating to PHP 8.0davidefa wrote: ↑Tue Nov 08, 2022 10:25 pm The php 8.0 update I published should be compatible even with php 7.4 ( at least I check on my php 7.4 test server )
I think my host www.ionos.com takes about 5 min (slow) to change php versions and hard to tell which blocks work and don't and miss the 5 minute data base update.
