ForecastIT needs updating
snow
Post by snow » Mon Jan 30, 2023 9:58 pm
On 25 January, the new site of the Italian Aeronautica Militare (meteo am), the source of the information used by the 'ForecastIT' block, went live.
The block is therefore no longer functional and needs an update.
Is anyone able to do this?
Thank you very much in advance.
:D
Re: ForecastIT needs updating
Post by davidefa » Tue Jan 31, 2023 9:18 pm
Yes the block need an update... I think it is doable
You may try the following preview, not complete, only local forecast should be 'ok' ( not 100% )
Rerun block setup, location setting has changed you have to specify latitude and longitude ( separated by a comma, no white chars )
forecastIT_2.3.zip
(125.97 KiB) Downloaded 522 times
snow
Post by snow » Fri Feb 03, 2023 1:24 pm
Hi davidefa,
I have tried the updated version of the block and indeed I think it still needs some modification. The local forecasts are not being updated automatically, therefore it still shows 1 February 2023 as today's date. Graphically, however, it seems to work correctly.
Edit: now the local forecast works correctly. We await the version that also includes weather for the Italian territory. Thank you very much! :D
snow
Post by snow » Sat Feb 18, 2023 10:14 pm
some news about this block?
