new fileMan ( file manager )
Post by davidefa » Wed Feb 08, 2023 9:05 pm
New file manager for meteotemplate, to upload/download/edit files directly from meteotemplate.
The file manager is available at the following address: admin/fileMan.php ( you need to be logged in as administrator )
To add the file manager to the menu you can add a line like the following:
File Manager|admin/fileMan.php|fa fa-file-text-o
v1.1
- corrected root directory definition ( in v1.0 was fixed to /template ), tanks to user FSC830
To configure the file manager you can add a admin/tfm_config.php file ( see tfm documentation )
fileMan_1.1.zip
(43.52 KiB) Downloaded 705 times
fileMan_1.0.zip
(43.5 KiB) Downloaded 614 times
Re: new fileMan ( file manager )
Post by andyk1 » Thu Feb 16, 2023 4:11 am
Awesome, Thank You David!
spd2612
Software: Meteobridge Pro 2
Post by spd2612 » Fri Mar 10, 2023 11:49 pm
Is this a plugin, or where does it install
Davis Pro 2
Meteobridge Pro2
GW 2000
WH57 Lightning Detector
Post by FSC830 » Sat Mar 11, 2023 6:31 am
Just copy the two files into the <template_root>/admin directory and add the line in (admin) menu setup.
spd2612
Post by spd2612 » Sat Mar 11, 2023 4:25 pm
well that link did not work for me I had to use
File Manager,https://hurricanepub.com/template/admin/fileMan.php
what does the rest of the url do It seems to work
Davis Pro 2
Meteobridge Pro2
GW 2000
