Netatmo station does not communicate with WeatherDisplay.
Posted: Tue Aug 15, 2023 9:19 am
by tobydude
Hasn´t communicated for several weeks.
Anyone have an idea why?
Re: Netatmo station does not communicate with WeatherDisplay.
Posted: Tue Aug 15, 2023 11:45 am
by tobydude
I can see that clientraw.txt is uploaded to the server but the data is old. Strange.
Posted: Fri Oct 20, 2023 3:50 pm
by El_Viejo
With the latest version of Weather Display (10.375S Build149) the Netatmo data updates work correctly.
Since Netatmo has changed the access conditions to their servers, I am looking for solutions. With the evaluation version of WD I have succeeded.
Posted: Fri Oct 20, 2023 4:09 pm
by tobydude
El_Viejo wrote: Fri Oct 20, 2023 3:50 pm With the latest version of Weather Display (10.375S Build149) the Netatmo data updates work correctly.
I have installed that version (10.375S Build149). Asked Brian Hamilton how to make Netatmo work on WD, but I don´t understand what he means. :/
Mail:
"Hi
u can setup WD to work directly with netatmo
udunv the latest vers
it has a new cronnetatmo program
you first log into your account in that new program..one time needed"
Where do I find "cronnetatmo program" in WD?
And what login to account does he refere to?
Posted: Fri Oct 20, 2023 6:00 pm
by El_Viejo
I am not aware of any special operations.
Under "Select Station Type", I selected the NETATMO station.
I am not sure, but I closed WD and when I opened it again, the connection script to the Netatmo servers was executed.
From this point on, the data from the Netatmo station appears in WD.
Then I linked WD to Meteotemplate (password and API url). I waited 10 minutes and, when I opened Meteotemplate, the data was updated periodically.
I've been testing for three hours and everything works correctly.
I can send you a screenshot of Meteotemplate, but I am unable to add images to my messages.
Posted: Fri Oct 20, 2023 6:06 pm
by tobydude
El_Viejo wrote: Fri Oct 20, 2023 6:00 pm
Yes , please send a screenshot. Will look at iit on monday when I em home.
Em at work right now and till monday. Thanks.
toby@vkbb.no
Posted: Fri Oct 20, 2023 6:31 pm
by El_Viejo
Posted: Mon Oct 23, 2023 1:33 pm
by johnathan
IT staff augmentation allows businesses to scale their workforce up or down as needed, responding to fluctuations in project requirements, without the need for long-term hiring commitments. Access to Specialized Skills: Companies gain access to a diverse pool of IT talents https://mlsdev.com/services/it-staff-augmentation with specific expertise, including software development, cybersecurity, cloud computing, data analytics, and more.
Posted: Mon Oct 23, 2023 2:16 pm
by El_Viejo
I suggest you check viewtopic.php?t=2445
Davide, has made a new Netatmo plugin, which does not require the use of Weather Display.
I have just installed it and, in my case, it works correctly.
Posted: Wed Oct 25, 2023 11:13 pm
by tobydude
Wow!
Look like Netatmo work on WD, now. :)
Thanks. :)
