Clone Meteotemplate redirects on moble
spd2612
Software: Meteobridge Pro 2
Post by spd2612 » Fri Nov 17, 2023 6:21 pm
I have set up a clone Meteotemplate which I renamed the Template folder and created a symlink to the the original sites MeteoTemplateLive
both sites are accessable and work fine Except when I try to access the Cloned site via Mobil device it redirects to the main site, It works fine on a desktop
I have looked at the index files and cant find anything that should cause this
anyone have any ideas here and yes I have cleared cache I must be missing something
original site https://hurricanepub.com
clone https://scpweather.com
how ever if I use the long url from a moble device it works https://scpweather.com/template1/indexMobile.php
Davis Pro 2
Meteobridge Pro2
GW 2000
WH57 Lightning Detector
spd2612
Re: Clone Meteotemplate redirects on moble
Post by spd2612 » Fri Nov 24, 2023 9:47 pm
the bottom mobile link on the main page also points to the hurricanepub page instead of scpweather
Davis Pro 2
Meteobridge Pro2
GW 2000
lemimi
Post by lemimi » Sat Nov 25, 2023 1:58 pm
Good morning,
Wouldn't there be a redirection in the .htaccess file?
Michel
spd2612
Post by spd2612 » Sat Nov 25, 2023 2:19 pm
I do not use a htaccess file meteotemple redirects according to weather it is mobile or desktop
Going to scpweather from desktop works as it should its just mobil that takes it to the other domain install
Davis Pro 2
Meteobridge Pro2
GW 2000
lemimi
Post by lemimi » Sat Nov 25, 2023 2:40 pm
Yes, I had tested your URL on my desktop and mobile and saw the redirect.
So maybe, just create a permanent link with the long URL via .htacess, for example:
RewriteEngine on
RewriteRule ^/?$ "https\:\/\/scpweather\.com\/template1\/indexMobile.php\/" [R=301,L]
spd2612
Post by spd2612 » Sat Nov 25, 2023 2:53 pm
I will try it
Davis Pro 2
Meteobridge Pro2
GW 2000
spd2612
Post by spd2612 » Sat Nov 25, 2023 3:33 pm
That did not work
I also changed the cookie name in the config file but no go there either
I dont no where the link at the bottom of the page comes from unless some of that comes from the DB becuse both URL"S use the same DB
Davis Pro 2
Meteobridge Pro2
GW 2000
lemimi
Post by lemimi » Sat Nov 25, 2023 3:58 pm
Another idea, has the address in the Paths section of the Main Template Setting been changed?
spd2612
Post by spd2612 » Sat Nov 25, 2023 5:09 pm
yes it has
All the other links work correctly and if I use https://scpweather.com/template1/indexMobile.php on a mobile device it goes there
Davis Pro 2
Meteobridge Pro2
GW 2000
Post by davidefa » Sat Nov 25, 2023 7:50 pm
In the main meteotemplate setup you can try setting the 'Mobile homepage' setting to Customizable.
spd2612
Post by spd2612 » Sat Nov 25, 2023 10:41 pm
davidefa wrote: Sat Nov 25, 2023 7:50 pm In the main meteotemplate setup you can try setting the 'Mobile homepage' setting to Customizable.
davidefa You got it again
I am not sure why but changing to customizable worked Great thanks for all the advice
Does not seem to be that many people on here anymore
Davis Pro 2
Meteobridge Pro2
GW 2000
lemimi
Post by lemimi » Sun Nov 26, 2023 8:40 am
Hello you two,
Davidefa has struck again... Bravo to him!
I just tested it, and it works perfectly.
Happy Sunday... Michel
