"Station climate" page non-functional after updating to 19.0 and PHP 8.x
T-man
After update to template 19.0 and PHP 8.x https://veikkola-saa.com/template/pages ... ndices.php shows only white page. I saw some discussion regarding similar failure, however I have normals in config.php
linux150
- Station model: WMR968
- Software: SDR -> Weewx -> MT
Re: "Station climate" page non-functional after updating to 19.0 and PHP 8.x
Any help, here the same after update 19 and php 8.3
LG
Martin
LG
Martin
- lemimi
Hello,,
Under PHP 8.xx, a fatal error results in a blank page.
See with T-man's link above: https://veikkola-saa.com/template/pages ... ndices.php
which results in a blank page.
Add ?errors to the end of the URL to see the error generated:
https://veikkola-saa.com/template/pages ... php?errors
If it can help you... Michel
enephler
- Station model: Davis Pro2
Meteotemplate 19 and PHP 8.x do not play well together. If you have the option, go back to PHP 7.x.
- lemimi
Like a few others, I'm still running Papaya version 18.0, but that has been modified here with the help of Davidefa to work under PHP 8.2.
I also found help thanks to ChatGpt and Rector PHP to improve my code.
This is indicated in the footer of my MeteoTemplate.
linux150
Hi!
Such a help would be great....
To stay on php 7 is no longer an option, because too expensive in support from my provider.
I think i will switch probably to 8.3 and check out what isnt working.
First of all i think the steel series is a big problem, ....
Greetings
Greetings
linux150
Now my site is running after a lot of updates on PHP8.3 expecting the climateindicies.php
Any help ?
Deprecated: Function utf8_encode() is deprecated in /home/.sites/50/site8222718/web/template/scripts/functions.php on line 44 Deprecated: Function utf8_decode() is deprecated in /home/.sites/50/site8222718/web/template/scripts/functions.php on line 47 Deprecated: Function utf8_encode() is deprecated in /home/.sites/50/site8222718/web/template/scripts/functions.php on line 47 Deprecated: Function utf8_decode() is deprecated in /home/.sites/50/site8222718/web/template/scripts/functions.php on line 119 Deprecated: Function utf8_encode() is deprecated in /home/.sites/50/site8222718/web/template/scripts/functions.php on line 44 Deprecated: Function utf8_decode() is deprecated in /home/.sites/50/site8222718/web/template/scripts/functions.php on line 47 Deprecated: Function utf8_encode() is deprecated in /home/.sites/50/site8222718/web/template/scripts/functions.php on line 47 Deprecated: Function utf8_decode() is deprecated in /home/.sites/50/site8222718/web/template/scripts/functions.php on line 119 Deprecated: Function utf8_encode() is deprecated in /home/.sites/50/site8222718/web/template/scripts/functions.php on line 44 Deprecated: Function utf8_decode() is deprecated in /home/.sites/50/site8222718/web/template/scripts/functions.php on line 119 Deprecated: Function date_sunrise() is deprecated in /home/.sites/50/site8222718/web/template/header.php on line 141 Deprecated: Function date_sunset() is deprecated in /home/.sites/50/site8222718/web/template/header.php on line 142 Fatal error: Uncaught Error: Call to a member function format() on false in /home/.sites/50/site8222718/web/template/pages/station/climateIndices.php:368 Stack trace: #0 {main} thrown in /home/.sites/50/site8222718/web/template/pages/station/climateIndices.php on line 368- lemimi
Here is the file, climateIndices.php, to decompress which works for me.
https://www.lemimi.fr/chargements/templ ... ndices.zip
Maybe he will do the same for you?
Michel
Michel
linux150
Many thanks, you made my day. Now the last part of my site working again.
Greetings Martin
Greetings Martin
T-man
Thank you! Works like a charm.lemimi wrote: ↑Thu May 02, 2024 8:21 pm Hello,
Michel
-Timo
for which plugin is this for?
grtz
alex
grtz
alex
- lemimi
Good morning,
If you open this page of your site:
https://www.sint-katelijne-waver-meteo. ... ndices.php
This displays a blank page, and if you add ?errors to the end of this url, you will see that you have a Fatal Error.
The file I provided for download above works well for me and has also solved the problem for a few people who had this problem.
Good luck... Michel
Good luck... Michel
hi,
thx found it, i was looking under 'plugins', and i'ts under 'pages' lol
grtz
a
grtz
a
- lemimi
Glad to have been able to help you...
Michel
Michel
- meteolopik
milesb
This is not an option with some hosting companies. I have the option to revert to PHP 7.x, but they will charge a "PHP7 support fee" that is greater than my monthly hosting fee.
