New dashboardCombined Block
Post by davidefa » Sun Feb 08, 2026 4:21 pm
This is a replacement for graphCombined block ( which does not work very well anymore ), updated to use the newer 'dashboard' feature of highcharts ( which is the library used to draw charts in meteotemplate ).
To use it you need to update your indexDesktop.php script near line 212 adding the following lines, after similar ones ( same for script indexFull.php near line 83 ):
        <script src="https://code.highcharts.com/dashboards/dashboards.js"></script>
        <script src="https://code.highcharts.com/dashboards/modules/layout.js"></script>
Configuration is the same as the graphCombined block.
ver 0.1 dashboardCombined
- initial release
ver 0.2 dashboardCombined
- corrected block naming error to dashboardCombined
ver 0.3 2026-02-10 dashboardCombined
- corrected aligment of x axis and data
If you have other charts in your homepage, please install the accompanying dashboardCombinedI block too.
This is an iframe that stops the interaction with other charts.
To use it you need to copy the included indexFull1.php and header1.php in your meteotemplate root directory and in your desktop layout you have to add the dashboardCombinedI
dashboardCombined_0.3.zip
(7 KiB) Downloaded 174 times
dashboardCombined_0.2.zip
(7.09 KiB) Downloaded 189 times
dashboardCombinedI_0.2.zip
(10.66 KiB) Downloaded 187 times
Re: New dashboardCombined Block
Post by alexvanuxem » Wed Feb 11, 2026 11:08 am
Hi David,
Thank you again!
With me only the iframe seems to work, is that the intention ?
Also the wind and windvector block doesn't work anymore , maybe the same issue as with the graphscombined block (highcharts)?
When I do ?errors after my sitename I hget a lot of errors with indexDesktop.php on line 144 (not related to your block):
for($i=0;$i<count($installedBlocks);$i++){
if($latestVersions['blocks'][$installedBlocks[$i][0]]>$installedBlocks[$i][2]){
$blocksToUpdate[] = $installedBlocks[$i][0];
} with example of error: Warning: Undefined array key "dashboardCombinedI" in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/template/indexDesktop.php on line 144
and in my php log [Wed Feb 11 12:04:25.237104 2026] [proxy_fcgi:error] [pid 2275211:tid 2275257] [client 84.197.91.132:0] AH01071: Got error 'PHP message: PHP Warning: Undefined array key "us" in /var/www/sint-katelijne-waver-meteo.be/sint-katelijne-waver-meteo.be/wwwroot/template/scripts/functions.php on line 122', referer: https://www.sint-katelijne-waver-meteo. ... php?errors
Any ideas?
Grtz
Alex
Post by davidefa » Thu Feb 12, 2026 10:03 pm
Well... I forgot a line, you have to add the following two lines to indexDesktop and indexFull:
Installing only dashboardCombined you may find other blocks 'performing strangely' ( this happened with graphCombined too ).
I updated the other blocks too for compatibility with php 8.5 ( will post updates ).
Would like to post a complete template update for php 8.5 ( still 'a few' things to complete )
Post by alexvanuxem » Fri Feb 13, 2026 9:42 am
Hi David,
the block is ok now. Thank you for that.
Thanks for all the good work!
I'm happy to help you and test things out if needed!
KR
Alex
