steelSeries
Posted: Sun Oct 08, 2017 4:51 pm
by Semtex
Hi
The uv max value is not present
is possible add ???
thanks
Re: steelSeries
Posted: Sun Oct 08, 2017 5:14 pm
It is, you need to activate it in the settings
Re: steelSeries
Posted: Sun Oct 08, 2017 7:20 pm
by Semtex
Hi
I say when scrolling over with the mouse
sorry but I do not find where activate.....
Re: steelSeries
Posted: Sun Oct 08, 2017 8:09 pm
in the SteelSeries plugin you need to set the UV gauge display to "true". It is set to false by default.
Re: steelSeries
Posted: Mon Oct 09, 2017 12:12 pm
by Semtex
Re: steelSeries
Posted: Mon Oct 09, 2017 12:18 pm
rule number one - all setup is done via GUI - NEVER go to the code directly, unless you want to make some customizations and know exactly what you are doing.
You need to open the setup page in a browser (via Plugin settings) and then in the second section from the top "Displayed Gauges" set UV to yes.
Re: steelSeries
Posted: Mon Oct 09, 2017 12:44 pm
by Semtex
- screenshot-meteobasaldella.it-2017-10-09-14-05-10.png (440.9 KiB) Viewed 10700 times
Re: steelSeries
Posted: Mon Oct 09, 2017 12:46 pm
by Semtex
"--" this is the error when scroll over uv index gauge
MAX TODAY
Re: steelSeries
Posted: Mon Oct 09, 2017 12:57 pm
Semtex wrote: ↑Mon Oct 09, 2017 12:46 pm
MAX TODAY
The plugin doesnt have info about UV. It only uses the current conditions file, which has current UV value.
