steelSeries
Re: steelSeries
It is, you need to activate it in the settings
- Semtex
- Station model: Davis Vantage Pro Plus 2
Re: steelSeries
I say when scrolling over with the mouse
sorry but I do not find where activate.....
Re: steelSeries
in the SteelSeries plugin you need to set the UV gauge display to "true". It is set to false by default.
- Semtex
Re: steelSeries
HI Jachym
plugin Steel Series - Setup
I find nothing set the UV gauge display to "true"
"UV":"<?php echo number_format($current['UV'],1,".","")?>",
"UVTH":"--",
http://meteobasaldella.it/plugins/steelSeries/index.php
http://meteoesine.it/template/plugins/s ... /index.php
http://www.philsweather.co.uk/meteotemp ... /index.php
http://www.meteopiateda.it/busteggia/pl ... /index.php
all with the same value --
"UVTH":"--",
Re: steelSeries
Hi,Semtex wrote: ↑Mon Oct 09, 2017 12:12 pm HI Jachym
"UVTH":"--",
rule number one - all setup is done via GUI - NEVER go to the code directly, unless you want to make some customizations and know exactly what you are doing.
You need to open the setup page in a browser (via Plugin settings) and then in the second section from the top "Displayed Gauges" set UV to yes.
- Semtex
Re: steelSeries
"--" this is the error when scroll over uv index gauge
MAX TODAY
MAX TODAY
- IMG_20171009_144111.jpg (465.51 KiB) Viewed 10700 times
