steelSeries
Semtex
Station model: Davis Vantage Pro Plus 2
steelSeries
Post by Semtex » Sun Oct 08, 2017 4:51 pm
Hi
The uv max value is not present
is possible add ???
thanks
Re: steelSeries
Post by Jachym » Sun Oct 08, 2017 5:14 pm
It is, you need to activate it in the settings
Semtex
Re: steelSeries
Post by Semtex » Sun Oct 08, 2017 7:20 pm
Hi
I say when scrolling over with the mouse
sorry but I do not find where activate.....
Re: steelSeries
Post by Jachym » Sun Oct 08, 2017 8:09 pm
in the SteelSeries plugin you need to set the UV gauge display to "true". It is set to false by default.
Semtex
Re: steelSeries
Post by Semtex » Mon Oct 09, 2017 12:12 pm
HI Jachym
plugin Steel Series - Setup
I find nothing set the UV gauge display to "true"
"UV":"<?php echo number_format($current['UV'],1,".","")?>",
"UVTH":"--",
http://meteobasaldella.it/plugins/steelSeries/index.php
http://meteoesine.it/template/plugins/s ... /index.php
http://www.philsweather.co.uk/meteotemp ... /index.php
http://www.meteopiateda.it/busteggia/pl ... /index.php
all with the same value --
Re: steelSeries
Post by Jachym » Mon Oct 09, 2017 12:18 pm
Semtex wrote: Mon Oct 09, 2017 12:12 pm HI Jachym
"UVTH":"--",
rule number one - all setup is done via GUI - NEVER go to the code directly, unless you want to make some customizations and know exactly what you are doing.
You need to open the setup page in a browser (via Plugin settings) and then in the second section from the top "Displayed Gauges" set UV to yes.
Semtex
Re: steelSeries
Post by Semtex » Mon Oct 09, 2017 12:44 pm
Semtex
Re: steelSeries
Post by Semtex » Mon Oct 09, 2017 12:46 pm
"--" this is the error when scroll over uv index gauge
MAX TODAY
Re: steelSeries
Post by Jachym » Mon Oct 09, 2017 12:57 pm
Semtex wrote: Mon Oct 09, 2017 12:46 pm "--" this is the error when scroll over uv index gauge
MAX TODAY
The plugin doesnt have info about UV. It only uses the current conditions file, which has current UV value.
