Current Block (v18.1) - Now showing UV
Posted: Mon Oct 09, 2017 11:38 am
by MonyMony
I have noticed that my Current Conditions block is now showing UV information. What is odd is not a sensor I have nor did I do anything knowingly to start showing this. How do I hide this once again as I do not see any option for this in the SETTINGS for this block?
Thanks!
http://www.cecilweather.com/weather/cec ... esktop.php
Re: Current Block (v18.1) - Now showing UV
Posted: Mon Oct 09, 2017 12:17 pm
MonyMony wrote: ↑Mon Oct 09, 2017 11:38 am
Thanks!
You didnt tell us what you are using to send data to the template (which SW), but whatever you use, it is sending UV information:
Raw data, notice the UV value:
http://www.cecilweather.com/weather/cec ... teLive.txt
This must be sorted in whatever is sending data to the template. If there is UV available, the template will think it is available.
Posted: Mon Oct 09, 2017 12:24 pm
by MonyMony
Jachym wrote: ↑Mon Oct 09, 2017 12:17 pm
Using WeatherCat v2.42B15. You are right that somehow in the software, where I have not looked at the preferences in months the UV setting was active.
Thanks for pointing me in the right direction to resolve this.
Posted: Mon Oct 09, 2017 12:42 pm
by MonyMony
Ok, spoke too soon. While there is an option in WeatherCat to show the UV gauges in the software, everything else related to this is automatically set. I have checked and my local software databases are showing all "0" for UV, and the UV sensor is showing invalid. That said the API is reporting a 16.0 for UV. I will post separately on the WeatherCat forum to make sure I am not missing a setting within the software that might explain this behavior. Still have odd it just started displaying this in the Current block in the past few days.
Posted: Mon Oct 09, 2017 2:28 pm
by Reinhard
Shot in the blue: Go to the control panel in Meteotemplate (NOT to main setup) and in the database section look for additional sensors. Maybe herein you can disable UV - at least you can disable saving UV readings to database.
Posted: Mon Oct 09, 2017 3:22 pm
This will have no effect on the Current block, the current block does not use db and uses whatever it finds in the current conditions file. This needs to be sorted in WC
Posted: Mon Oct 09, 2017 4:17 pm
by nikokara - BANNED
Monymony
I can tell you how to hide it (by changing the code in the block),
but first I need Jachims permission.
Posted: Mon Oct 09, 2017 4:22 pm
I dont mind
But this should be sorted in WC because it will cause problems at other places too. If there is UV value sent to the template, it assumes it is available.
Posted: Mon Oct 09, 2017 4:45 pm
by Reinhard
Now you know that I am using WeatherCat as well, and after all I do have no problems with the auto-API-feed WC offers. MonyMony, maybe we can discuss this issue in the WeatherCat forum.
Posted: Mon Oct 09, 2017 5:17 pm
by MonyMony
Reinhard wrote: ↑Mon Oct 09, 2017 4:45 pm
Yes, I know you are a fellow WeatherCat user! I even checked your page before posting. I am going to post this to the WC page later this evening we we can certainly discuss there.
Posted: Tue Oct 10, 2017 12:28 pm
by MonyMony
nikokara wrote: ↑Mon Oct 09, 2017 4:17 pm
Thank you for the offer. Depending on what I find out from the software side I might just do this but for the moment I will just wait.
Posted: Wed Oct 11, 2017 12:50 pm
by MonyMony
Reinhard wrote: ↑Mon Oct 09, 2017 2:28 pm
Sorry, forgot to respond to this that I have already checked this and I am not saving this value. Good thought though!
Posted: Wed Oct 11, 2017 9:34 pm
by MonyMony
Hello All,
I have heard back from the WeatherCat developer who provided me a process to see exactly what the software is sending to the Meteotemplate API. When I do this I see this:
WeatherCat[266]: MeteoTemplate: ?U=1507753881&B=80&W=1.6&G=3.2&H=77&T=23.0&HIN=50&TIN=29.6&RR=0.00&R=0.00&P=1016.32&S=1746&LW4=0
The developer went on to state that if UV information was being sent by WeatherCat I would see '&UV=x.x' in the string which I do not.
I also noticed that the temperature values I am seeing in the string sent by WeatherCat do not match what is shown in the cache files 'latestApiCache.txt' and 'latestApiLog.txt' where there are a crazy amount of places after the decimal place shown.
{"U":1507757127,"B":13,"W":0,"G":1.600000000000000088817841970012523233890533447265625,"H":82,"T":21.89999999999999857891452847979962825775146484375,"HIN":50,"TIN":29.5,"RR":0,"R":0,"P":1016.490000000000009094947017729282379150390625,"S":1747,"LW4":0,"SW":"WeatherCatV2.42B15","UTime":1507757127,"BTime":1507757127,"WTime":1507757127,"GTime":1507757127,"HTime":1507757127,"TTime":1507757127,"HINTime":1507757127,"TINTime":1507757127,"RRTime":1507757127,"RTime":1507757127,"PTime":1507757127,"STime":1507757127,"LW4Time":1507757127,"SWTime":1507757127,"UV":16,"UVTime":1507757127,"D":18.699999999999999289457264239899814128875732421875,"DTime":1507757127,"A":25,"ATime":1507757127}
After seeing this I have noticed that WeatherCat is reporting my information in Metric values but the API looks to be converting them to Imperial Units if I look at 'latestApiLog.txt.
{"timestamp":["1507756226","1507756286","1507756346","1507756406","1507756466"],"date":["2017-10-11 17:10:26","2017-10-11 17:11:26","2017-10-11 17:12:26","2017-10-11 17:13:26","2017-10-11 17:14:26"],"T":[71.960000000000007958078640513122081756591796875,71.960000000000007958078640513122081756591796875,71.960000000000007958078640513122081756591796875,71.780000000000001136868377216160297393798828125,71.780000000000001136868377216160297393798828125],"H":["81","80","80","80","80"],"P":[30.008956275600002783221498248167335987091064453125,30.008956275600002783221498248167335987091064453125,30.008956275600002783221498248167335987091064453125,30.01102337420000054635238484479486942291259765625,30.011909273600000602755244472064077854156494140625],"W":[0,0.99419360000000001065245669451542198657989501953125,0.99419360000000001065245669451542198657989501953125,0,0.99419360000000001065245669451542198657989501953125],"G":[0.99419360000000001065245669451542198657989501953125,1.9883872000000000213049133890308439731597900390625,1.9883872000000000213049133890308439731597900390625,0.99419360000000001065245669451542198657989501953125,1.9883872000000000213049133890308439731597900390625],"B":["38","38","38","38","37"],"R":[0,0,0,0,0],"RR":[0,0,0,0,0],"D":[65.840000000000003410605131648480892181396484375,65.4800000000000039790393202565610408782958984375,65.4800000000000039790393202565610408782958984375,65.30000000000001136868377216160297393798828125,65.30000000000001136868377216160297393798828125],"A":[77.539999999999992041921359486877918243408203125,76.81999999999999317878973670303821563720703125,76.81999999999999317878973670303821563720703125,77.18000000000000682121026329696178436279296875,76.6400000000000005684341886080801486968994140625]}
Could this translation be where I am picking up the UV? I also noticed in the latestApiCache.txt file that initial values reported at the top of the file do not show anything related to UV.
[quote]Authorized access.
Current date/time: 2017-10-11 17:25:27
api called by http
update U: 1507757127
update B: 13
update W: 0.0
update G: 1.6
update H: 82
update T: 21.9
update HIN: 50
update TIN: 29.5
update RR: 0.00
update R: 0.00
update P: 1016.49
update S: 1747
update LW4: 0
update SW: WeatherCatV2.42B15[/quote]
Hopefully we are starting to zero in on the root cause here.
Posted: Wed Oct 11, 2017 9:42 pm
the data sent to the API should always be in metric and the template therefore performs no conversion to it because it needs it in metric.
Check: meteotemplateLive.txt - this is the raw data sent to the template taken from the string sent by WC and saved before further processing
Posted: Wed Oct 11, 2017 9:50 pm
by MonyMony
Checked and file shows this:
{"U":1507758388,"B":5,"W":0,"G":0,"H":85,"T":21.5,"HIN":50,"TIN":29.699999999999999289457264239899814128875732421875,"RR":0,"R":0,"P":1017.1000000000000227373675443232059478759765625,"S":1746,"LW4":0,"SW":"WeatherCatV2.42B15","UTime":1507758388,"BTime":1507758388,"WTime":1507758388,"GTime":1507758388,"HTime":1507758388,"TTime":1507758388,"HINTime":1507758388,"TINTime":1507758388,"RRTime":1507758388,"RTime":1507758388,"PTime":1507758388,"STime":1507758388,"LW4Time":1507758388,"SWTime":1507758388,"UV":16,"UVTime":1507758388,"D":18.89999999999999857891452847979962825775146484375,"DTime":1507758388,"A":24.699999999999999289457264239899814128875732421875,"ATime":1507758388}
WeatherCat is reporting sending this:
WeatherCat[266]: MeteoTemplate: ?U=1507758388&B=5&W=0.0&G=0.0&H=85&T=21.5&HIN=50&TIN=29.7&RR=0.00&R=0.00&P=1017.10&S=1746&LW4=0
Something odd is going on before the meteotemplateLive.txt file is created.
Posted: Wed Oct 11, 2017 10:15 pm
You can ignore the decimals, thats due to the variable type, but that UV... it must come from somewhere
I guess we will need to do some test script to really save the raw data even before meteotemplateLive.txt is created. Email me your admin password and I will look at it tomorrow.
Posted: Wed Oct 11, 2017 10:35 pm
by Luc
Jachym wrote: ↑Wed Oct 11, 2017 9:42 pm
Since v16 adjustment variables are added to Temperature and Pressure and multiplied for Daily precipitation and Wind Speed. See section 'Adjustments' in the main settings file.
May be we should save the results of the adjustments in meteotemplateLive.txt with three decimals.
Posted: Thu Oct 12, 2017 12:58 am
The problem here is where the uv is coming from
Posted: Thu Oct 12, 2017 1:42 am
by MonyMony
Jachym wrote: ↑Wed Oct 11, 2017 10:15 pm
Private email sent... thank you!
Posted: Thu Oct 12, 2017 2:08 am
by Luc
Hi MonyMony,
Can you please delete the file meteotemplateLive.txt?
Then the UV information should be gone in your current block.
Luc
Posted: Thu Oct 12, 2017 8:59 am
This needs to be taken into account in the next update (v17), there is a problem with the API and how it handles the data. In particular, once you send UV to the template, the reference to it stays there forever regardless of whether you are still sending it. Deleting meteotemplateLive.txt should solve it.
Posted: Thu Oct 12, 2017 12:03 pm
by MonyMony
Jachym wrote: ↑Thu Oct 12, 2017 8:59 am
I can confirm removing the file resolved this. Now how the UV reading initially got in there in the first place is anyone's guess. At least there is a work-around and an understanding of what is going on. Thanks everyone for the help!
Posted: Thu Oct 12, 2017 12:53 pm
by Luc
MonyMony wrote: ↑Thu Oct 12, 2017 12:03 pm
For me it's not because you told us yourself how it got there!
Posted: Thu Oct 12, 2017 2:01 pm
by MonyMony
I guess the software is the possible source by sending a random one-time UV entry, but no way to prove. I would have to turn on logging for everything sent by WeatherCat to try and catch a stray entry. Maybe a crash that I did not know about caused a garbage submission... I really have no idea.
Posted: Thu Oct 12, 2017 6:00 pm
by Reinhard
Glad you sorted it out!
