hello
big concern for me obviously with the Webcam plugin and the time_lapse
http://seremange-meteolive.franceserv.c ... /index.php
i have uopald the last image but the script does not want to work with the url generated by the server MeteoBridge type "content.meteobridge.com" while everything returns to normal if I change the url and takes as a reference, for example, that of the integrated ddns
an idea ?
in advance thank you and good Sunday
REGARDS
Plugin "webcam" bug uoplag time-lapse
- bianco57
- Station model: Davis Vp2 PLUS
- Software: Meteobridge Proi
Davis Pro 2+ * SEREMANGE ERZANGE FR57
by MeteoTemplate
http://valdefench57sgz.franceserv.com/m ... esktop.php
by Infoclimat StatIC FR
http://www.infoclimat.fr/observations-m ... 000T5.html
by MeteoTemplate
Re: Plugin "webcam" bug uoplag time-lapse
Hi Bianco,
so if I understand this correctly, you were using the webcam plugin and after changing the URL it no longer works?
If this is the case then there must be a problem in that url. Either it is behind some firewall, port or it is not a valid format.
What exactly is the new url?
- bianco57
Hi Jachym
thanks for your return
yes I use the plugin./Webcam for 2 sites
I have two url:
it works ok if I enter that of the manufacturer ddns (Foscam)
she is of the type:
http://jv7240.myfoscam.org:8080/cgi-bin ... e&cnt=.jpg
http://cs2636.myfoscam.org:88/cgi-bin/C ... =&cnt=.jpg
but if I modify the url (the one I generate via MeteoBridge_WeatherCam) it does not want/no longer work properly
she is of the type:
http://content.meteobridge.com/cam/5c81 ... amplus.jpg
http://content.meteobridge.com/cam/6b63 ... amplus.jpg
note that it runs perfectly in another User (who kindly passed me the overlayxt to display the banner data weather)
http://www.wessexweather.net/meteotempl ... esktop.php
ps
i just saw on one of my sites, the uolad worked well for two/three images then again "out" ? ...
I have two url:
she is of the type:
she is of the type:
ps
by MeteoTemplate
by MeteoTemplate
Im afraid if the problem is the URL you would need to ask your provider about this, this is obviously not a problem with the plugin as such because it works for you with a different url. Most likely for some reason there is no communication between your server and MB server
- bianco57
re_thnx
mysteriously the uoplad for the time_lapse is intermittently and as seen on the log_MB nothing to report ... WeatherCam MB works properly! ..?
http://www.cjoint.com/c/GJwpNPEWiV7
by MeteoTemplate
by MeteoTemplate
