in the process of setting up the template, so far its working with the old weatherstation (Davis WM 2 - need new cables...).
I also have a 'air quality monitoring station' (uradmonitor A3-sensors for Gamma radiation, formaldehyde, CO2, VOC Air quality, temperature, barometric pressure, air humidity, PM2.5 particulate matter).
The unit can output the data on a local ip in json format.
Is there a way to put this data into the database and template ?
(old) weatherstation : http://weer.on1gl.be
air quality : http://air.on1gl.be
adding a second station (air quality) ?
- Asobig
- Software: Meteobridge (Red)
Re: adding a second station (air quality) ?
I got the same device and made a script to display the JSON data (see my signature). At this moment it's just that. I also would like to store the data in a database and make graphs out of data. It doesn't have to be in the Meteotemplate database (for me).
ON1GL
- Software: Meteotemplate/MeteoBridge
glad i'm not alone
You got already a good start in displaying the data....
Any database will do, still having space on the NAS....
- Asobig
I made a script to store the data in a database and display them under the current readings. So if you click 'more' you will see the graphs.
It works with a cron job on my NAS. It takes the data from the JSON stream and puts them in a database.
It's not perfect, but it works.
You can check it out on my site.
- BobW55
- Station model: Davis Pro2
Do you have a link to the sensor you are using?
I was looking at the Purple Air Sensor, but it does not do Ozone.
Bob
Bob
Davis Vantage Pro2 wired
Solar/UV sensors
Sky Cam
Ham radio K8pos
Solar/UV sensors
Sky Cam
Ham radio K8pos
ON1GL
take a look at this website, there are different models, the A3 is in use here
https://www.uradmonitor.com/products/?sel=4
73
Luc
73
Luc
- Asobig
At this moment there is a Campaign at Indiegogo for funding the new version.
https://www.indiegogo.com/projects/air- ... -network#/
