webcam block - export as image does not work
Post by meteoesine » Tue Nov 14, 2017 11:06 am
I noticed on my site the image is not exported clicking on the relative icon.
Is it maybe due to the php extension of my webcam image instead of a jpg?
the image coming from 'bloomskylatest.php' script
thanks for any comments
Norbert
Re: webcam block - export as image does not work
Post by Johnny » Tue Nov 14, 2017 1:21 pm
Hi Norbert, not that I'm qualified to answer your problem, but some of your blocks do allow a .jpg export. current.jpg, uv.jpg, moonPhase.jpg, stationDeviation.jpg, dynamicImage.jpg the remaining ones don't.
staccermaccer
Station model: Davis pro plus II
Software: WD, CUMULUS
Post by staccermaccer » Tue Nov 28, 2017 2:27 pm
Hi, all
I also would like to know if there is any possibilty to take a snapshot every 10 minutes or so from an ipcam?
because i am using a foscam ipcam to look at the conditions in my hometown....
Greetings from Antwerp, Belgium
BobW55
Post by BobW55 » Tue Nov 28, 2017 2:45 pm
staccermaccer
Have a look at my site; www.melvinweather.com
I use a program called IP Time Lapse: http://iptimelapse.com/
It does all the work for me. Uploads an image from my IP cam every 5 minutes, and creates two different time lapse videos for me. I run it and Cumulus from the same PC.
Davis Vantage Pro2 wired
Solar/UV sensors
Sky Cam
Ham radio K8pos
cw3beck
Post by cw3beck » Tue Nov 28, 2017 7:37 pm
Bob,
Nice clear images. Can I ask what webcams you are using to capture the stills?
