Current Block v19.0 issue
geoarv
Software: Weather Dislpay
Post by geoarv » Thu Nov 16, 2017 5:39 pm
I've installed the current block and it's working ok but only update every 30 seconds.
I'm changing the block settings to update every 5 or 10 or what ever seconds but nothing changes.
http://geoarv.sytes.net/
Any ideas?
Re: Current Block v19.0 issue
Post by Jachym » Thu Nov 16, 2017 6:00 pm
geoarv wrote: Thu Nov 16, 2017 5:39 pm Hi,
Any ideas?
It depends how quickly you are sending data to Meteotemplate. if you are sending data to MT every 30s, then even if you set the block to 5s, it will be loading the same file every 5s
geoarv
Post by geoarv » Fri Nov 17, 2017 8:31 am
I am feeding every 5 secs (also tried 3 secs, 10 secs) from WD but what i'm asking for is for the update to take place (flash) every x secs (lets say 5) as it's supposed to do in the block parameters.
This doesn't happen and i get the flashing of the time in my main page only every 30 secs and i have already set this in the current block to refresh every 5 secs. It is as if i change the parameter in the block settings and it doesnt change the time of the update.
Hope this is more clear.
Thank you Jachym.
geoarv
Post by geoarv » Tue Nov 21, 2017 5:09 pm
Any news on the issue maybe?
Post by Jachym » Tue Nov 21, 2017 9:22 pm
I checked your homepage, the block is requesting new data every 5s. However it will not flash if it gets the same data as it did last time. This suggests that even though you are updating the template every 3 or 5s, the same data is sent to the api so it ignores it
