Monthly/Yearly rain data adjustment
- hdultra103
- Software: Weewx
Is there anyway to change the yearly and monthly rain totals? Thanks.
Re: Monthly/Yearly rain data adjustment
Meteotemplate does not use any monthly/annual tables. Everything is calculated from the alldata table, which means that if you want to modify any totals, it is possible, but has to be done by modifying the data in the alldata table, which you can do for example using the edit data feature in the control panel.
