Most graphs/options not responding
Posted: Thu Nov 30, 2017 9:20 pm
I'm having a problem with most of the graphs in meteotemplate not working.
Current Data page works fine. Past that, it gets sort of hit and miss.
Interactive graph page loads, but sits with the spinning indicator. I scrolled up, and noticed this at the bottom of the page of the Interactive graph. The Weather/Outlook page loads, but no icons/buttons respond. no graphs seen.
The only graph I can see working, is the station climate. Things I have tried;
Removed it from the server, reinstalled twice to make sure all files were replaced.
Tested with 2 different computers (Linux)
Tested with Google Chrome, Firefox, and Chromium
I then did an installation on another domain I have. Works exactly the same way. Still the odd "ok" box and to-from at the bottom of the page.
I tried the installations after clearing cache, rebooting machine, clearing cookies.
I tried installing and leaving off the Interactive header.
I also did as basic an install as possible as far as optional options.
Each time I reinstalled, the files were removed from server, database deleted and new one set up.
Java script is enabled, no popup blocker, no ad-blocker.
Could it be that when I downloaded the template file, it corrupted for some unknown reason? and that is why totally replacing the files on each install makes no difference?
I'm stumped, the template loads without hesitation. No problem changing any settings.
The database is updating as it should.
Any help appreciated to figure it out. I really like the program.
Link to the site is http://www.castlekeepdanes.com/weewx2/t ... esktop.php
Thanks,
Ron
Thanks,
Ron
