I have noticed an errors in the temperature average.
From top to bottom, the averages that are visible on this chart are:
December avg = 1.2°
December normal = 0.8°
December 2017 = -1.1°
But according to the various stats plugins, the December avg is 1.67° (vs 1.2° in zhe chart):
The same problem occurs with rain: Dec avg is 33.4mm vs 27.4mm displayed in the block.
I haven't checked for the other parameters.
Second I have a wish regarding the settings of this block: its default showing is "collapsed". Could you add an option in the settings to choose "collapsed" or "extended", as you did for several other blocks ?
Thanks for everything !
