Hi Jachym,
Like to have the same Forecast block as below,
but display hourly forecast instead of daily forecast; and allow me to have parameter setup like this:
- fixed from, say 6pm till 6pm next day
- display every x hour, e.g. 3 hourly forecast
or just set up from, say 6pm till 5pm, then the block fixes the number of weather icons to 6 during such defined period.
As an amateur astronomer, usually, we are only interested in the forecast during the night time.
I intend to put the hourly forecast just below the daily forecast, like this
Pleases consider..thanks.
Hourly Forecast
Re: Hourly Forecast
you can use the Outlook block for this, it shows exactly what you meant - an hourly forecast
- bthoven
- Station model: Misol WH2600
- Software: weewx
Re: Hourly Forecast
Hi Jachym,
I would like to have a compact version of it, so that it can be part of the "one page" dashboard on my always-on tablet.
Re: Hourly Forecast
I believe the Outlook block is as compact as you can get it, it is expandable and showing 24 icons/conditions will always take up some space
