French translation problem
Discussion about language files
Thomas
Post by Thomas » Sat Dec 30, 2017 1:42 pm
I use French language, I think there is a problem with the accents. This causes bugs for example in the temperature analysis plugin, the graph does not appear.
    When I switch to English language, it works.
      When I modify the file "fr.php" I replace:
      "temperature balance":"\u00e9quilibre de la temp\u00e9rature"
      by
      "temperature balance":"\u00e9quilibre de la temperature", it works.
      There are also accents problems in the menu that are replaced by symbols.
      Thank you !
      Station Météo Alès: www.meteoales.fr
      Re: French translation problem
      Post by Jachym » Sat Dec 30, 2017 1:57 pm
      yes, I see. I need to replace the accents with their HTML parts. i will do it once things calm down (few days, Im busy now with v17). In case I forget, please email me in 2-3 days about this I will fix it.
      Thomas
      Post by Thomas » Sat Dec 30, 2017 2:12 pm
      ok it's not urgent.
      Thomas
      Post by Thomas » Wed Jan 03, 2018 5:05 pm
      HI Jachym,
      can you look for this problem ?
      Post by Jachym » Wed Jan 03, 2018 5:22 pm
      yes we can do it, but I would need a list of which phrases are causing the issue. It is strange because in Czech we also have ěščřéíáýř etc. and they all display correctly in the menu as well
      Post by Jachym » Wed Jan 03, 2018 5:24 pm
      Update your language files, the equlibirium problem should be solved
      Thomas
      Post by Thomas » Wed Jan 03, 2018 5:28 pm
      I just updated languages, it's works now...
