Hi Has anybody else seen the same problem?
Generate a annual report in the reports section., the correct max temperature is displayed onscreen, however when generating a printed report via the PDF icon the max temperature are printed out as garbage results.
E.g. my annual report for 2017 gives the correct maximum temp of 31.1 c with the correct time and date (18.06.2017) from my database. However the PDF annual report summary (page 1) gives a reading of 0.0 c with the correct date/time(18.06.2017).
Page 2 of the PDF report gives a warmest day temperature of 22.55 c for the 18.06.2017 which is obviously incorrect. Should be 31.1 c.
I have noticed the same incorrect results for all my annual report summaries from 2012 onwards when printed out. Correct temp readings are on screen but incorrect when printed out.
John C
Incorrect Max temperatures in Annual Report
marc@geissmann.org
Re: Incorrect Max temperatures in Annual Report
After a check on my website, I have the same issue here.
Rgds Marc
Rgds Marc
try clearing the station cache in control panel.
if that does not help I will look at it, but right now Im extremely busy with the updates, 300+ emails just today. Once things calm down I will release a fix for the new mobile homepage and then we can look at this
