Moblie Menu Problem
- danville
- Software: WeeWx
Moblie Menu Problem
On iPads and Androids my automatic Mobile menu is fully expanded and not functioning as a drop-down. On my PC, choosing the Mobile menu works properly. How can I set up Meteotemplate to look like the menu on the right below on iPads and Androids?
- ipadmeteotemplateproblem.jpg (214.27 KiB) Viewed 2709 times
Re: Moblie Menu Problem
this is a known problem that only affects Apple devices. I googled it and it seems like some unusual function or bug in Safari. I tried various solutions non of which worked. The menu uses only standardized scripts so it is likely some incompatibility issue of Safari, but given I dont even have access to any Apple device I cant test it. This was one of the main reasons I created the new homepage, which uses Bootstrap and is compatible with any device and OS type.
