moonPhase Block Icons
psper
Station model: Davis Vue
Software: Weather
Post by psper » Mon May 31, 2021 3:21 pm
Hi all,
I use moonPhase Block but moon icons are correct only for South Hemisphere.
I think that for North hemisphere they are wrong.
It is diferente between north and south hemisphere.
Do you know how to correct this?
Thanks in advance,
Paulo
WhatsApp Image 2021-05-31 at 16.07.31.jpeg (43.9 KiB) Viewed 42374 times
Re: moonPhase Block Icons
Post by davidefa » Mon May 31, 2021 4:37 pm
I have already 'reordered' the look of the block and added the moon age indication
moonPhase_2.1a.zip
(64.39 KiB) Downloaded 879 times
psper
Software: Weather
Post by psper » Fri Jun 04, 2021 4:52 pm
Hi!
Did you change the png files or the moonPhaseBlock.php file?
Thanks !
Paulo
Post by davidefa » Fri Jun 04, 2021 5:23 pm
The php script ( as I also reordered the phases )
Meteofabro
Software: Meteobridge RED PRO
Post by Meteofabro » Sun Jan 30, 2022 2:16 pm
For those wishing to try the Moonphase block with the real-time graphics of the Moon-Earth phases, you can download the block in ZIP format attached below.
Remember to save the original block on the server or on your PC if you want to restore.
2022-01-30 14_54_38-Moonphase.png (169.07 KiB) Viewed 41974 times
moonPhase_2.1b.zip
(65.04 KiB) Downloaded 933 times
Post by davidefa » Sun Jan 30, 2022 8:01 pm
Nice!
Meteofabro
Post by Meteofabro » Mon Jan 31, 2022 3:14 pm
UPDATE to the moonPhase block.
The "Show the other side of the Earth on the Earth-Moon image" configuration has been added to the block.
This setting displays the opposite side of the Earth (Pacific zone) to the standard position (Atlantic zone).
Useful for Meteotemplate users to view the terminator (fictitious line on the Earth that delimits the illuminated part from the shaded part) on their Continent.
2022-01-31 16_12_28-MeteoFabro.png (316.07 KiB) Viewed 41956 times
moonPhase_2.1c.zip
(64.69 KiB) Downloaded 1220 times
tobydude
Software: Weatherdiaplay
Post by tobydude » Mon Mar 07, 2022 4:57 pm
Meteofabro wrote: Sun Jan 30, 2022 2:16 pm For those wishing to try the Moonphase block with the real-time graphics of the Moon-Earth phases, you can download the block in ZIP format attached below.
Thanks. :)
Post by davidefa » Sun Nov 12, 2023 4:13 pm
ver 2.3
- updated earth/moon visualization ( to use fourmilab scripts )
- added few configuration option
ver 2.4
- removed stale css #footer definition ( which caused a footer text color change )
moonPhase_2.4.zip
(65.95 KiB) Downloaded 1235 times
moonPhase_2.3b.zip
(65.96 KiB) Downloaded 1299 times
Jolumarali
Station model: Vantage Vue
Software: WlIP
Post by Jolumarali » Sun Nov 12, 2023 6:15 pm
Thank you Davide, installation without problem, we missed you very much
José Luis :)
MeteoElMasnou
Post by MeteoElMasnou » Mon Nov 13, 2023 6:40 am
Thanks for the update Davidefa.
Greetings
djpoppy
Station model: GW2000 - WS90
Post by djpoppy » Mon Nov 13, 2023 7:16 am
Great update @Davidefa ;)
lemimi
Post by lemimi » Mon Nov 13, 2023 7:20 am
In boredom... just ask and Davide does it!
Many thanks... Michel
Meteofabro
Post by Meteofabro » Tue Nov 14, 2023 3:49 pm
Un aggiornamento fantastico, GOOD...
tobydude
Post by tobydude » Tue Nov 14, 2023 4:18 pm
version":2.3b works fine here. Thanks.
Jolumarali
Software: WlIP
Post by Jolumarali » Sun Nov 26, 2023 10:41 am
Hello Davide, Since the installation of moonPhase Block, the footer has some sharpness problems, test carried out uninstalling the Block. ditto on different browsers and on sites that have installed it.
Do you have any idea about this problem.
and thank you for your work
Post by davidefa » Sun Nov 26, 2023 1:27 pm
Yes, you are right, there was an an erroneous css definition that caused this.
Updating to v2.4 should fix it: viewtopic.php?t=2068#p12849
Jolumarali
Software: WlIP
Post by Jolumarali » Sun Nov 26, 2023 1:47 pm
Thank you Davide, We can never thank you enough. :)
MeteoElMasnou
Post by MeteoElMasnou » Sun Nov 26, 2023 8:09 pm
davidefa wrote: Sun Nov 26, 2023 1:27 pm Yes, you are right, there was an an erroneous css definition that caused this.
Thanks Davide.
