PHP 7.1.8 and 1&1
Zedekia
PHP 7.1.8 and 1&1
Post by Zedekia » Mon Aug 21, 2017 3:01 pm
Hello Jachym and the other member,
I would like to post my problem in your new forum, maybe someone has the same problem in the future.
My new hoster is 1&1 and the PHP-Version is 7.1.8
As soon as I have registered in the admin area .../admin/login.php and I've entered my pwd., it does not go on and the website remains with ... / admin / authorize.php.
Jachym told me, I should temp. modify the config.php with add the line
error_reporting(E_ALL);ini_set('display_errors', 'On');
The result are the following error-messages:
Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; moonPhase has a deprecated constructor in /homepages/9/d694096150/htdocs/zedekia/wetter/mt/template/scripts/functions.php on line 2169
Warning: session_start(): Cannot send session cookie - headers already sent by (output started at /homepages/9/d694096150/htdocs/zedekia/wetter/mt/template/scripts/functions.php:2169) in /homepages/9/d694096150/htdocs/zedekia/wetter/mt/template/admin/authorize.php on line 41
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /homepages/9/d694096150/htdocs/zedekia/wetter/mt/template/scripts/functions.php:2169) in /homepages/9/d694096150/htdocs/zedekia/wetter/mt/template/admin/authorize.php on line 41
Warning: Cannot modify header information - headers already sent by (output started at /homepages/9/d694096150/htdocs/zedekia/wetter/mt/template/scripts/functions.php:2169) in /homepages/9/d694096150/htdocs/zedekia/wetter/mt/template/admin/authorize.php on line 111
I have also modified the php.ini like this:
zlib.output_compression=1
zlib.output_compression_level=9
error_reporting = E_ALL & ~E_NOTICE | E_DEPRECATED
display_errors = Off
display_startup_errors = Off
log_errors = On
log_errors_max_len = 1024
ignore_repeated_errors = Off
ignore_repeated_source = Off
report_memleaks = On
allow_url_fopen = On
track_errors = Off
xmlrpc_errors = 0
html_errors = Off
error_log = php-error.log
register_globals = on
allow_url_fopen = on
allow_url_include = on
No results.
The "master" Jachym is already concerned about the problem.
Best Regards (and sorry for my broken English)
Alexander
Re: PHP 7.1.8 and 1&1
Post by Jachym » Mon Aug 21, 2017 3:06 pm
Hi Alex
the errors you see are fine, the first is a notice (irrelevant to this issue), the following errors are due to this notice being displayed. It really is a mystery to me. I was looking at your page again, but it just doesn´t show any errors and ends up with a blank page.
Do you have access to error log?
Btw. I use PHP 7.1 too, so it should not be an issue
Zedekia
Post by Zedekia » Mon Aug 21, 2017 6:06 pm
Hello Jachym,
Problem solved. I make a clean-install. Great. PHP 7.1 is so fast.......
Thank you Jachym.
Alex.
Post by Jachym » Mon Aug 21, 2017 6:22 pm
Great :-)
Yes, PHP 7+ is about twice as fast compared to PHP 5.x.
It is also easier for programmers to do certain things, but unfortunately this is something I cannot use because it would not work on 5.x servers.
scadie
Station model: Davis Vantage Pro
Post by scadie » Mon Aug 21, 2017 9:13 pm
I like this new forum, following your discussion, I check my hosting and see running PHP 5.6... I change it to 7.0 and run really much faster......
Sylvain Cadieux
scadie@scadie.com
Meteo Saint-Hubert: http://www.meteosaint-hubert.com
Didiersm
Station model: WMR200
Software: Weathe rDisplay
Post by Didiersm » Tue Aug 22, 2017 7:15 pm
I have changed my PHP version from 5.6 to 7 too... waouuu as faster is it compare to the 5.6.
Thanks Jachym for this tips, really usefull :P
Station WMR200
Fontenilles Wheather - FR http://didiersm.16mb.com/template/indexDesktop.php
mailto:didier.sm@gmail.com
Post by Johnny » Tue Aug 22, 2017 9:14 pm
I've just updated mine as well - great tip. :D
John B
Post by John B » Wed Aug 23, 2017 4:17 am
What a difference!
I too have changed from 5.XX to 7.1 and am most pleased with the performance (relatively speaking, of course). It had never occurred to me that shifting to a later version of PHP would make such a difference.
Thanks to all for bringing the subject to our attention.
Cheers,
barbuser
Post by barbuser » Thu Aug 24, 2017 9:48 am
I have updated mine to 7.X. Thanks so much for the tip!
kd7eir
Station model: Ecowitt Wittboy
Software: FOSHKplugin
Post by kd7eir » Fri Aug 25, 2017 6:32 pm
I'm also with 1&1 on php 7.1.8, and I have not had any issues at all.
Post by Jachym » Fri Aug 25, 2017 8:44 pm
Thanks for letting me know, this means the person who had problems with 7.1.8 must have some missing parts of PHP. I have seen this with one other user before, where some functions which should normally be available were not installed.
