PHP 7.1.8 and 1&1
- Zedekia
- Station model: Davis Pro2
PHP 7.1.8 and 1&1
Hello Jachym and the other member,
I would like to post my problem in your new forum, maybe someone has the same problem in the future.
My new hoster is 1&1 and the PHP-Version is 7.1.8
As soon as I have registered in the admin area .../admin/login.php and I've entered my pwd., it does not go on and the website remains with ... / admin / authorize.php.
Jachym told me, I should temp. modify the config.php with add the line
error_reporting(E_ALL);ini_set('display_errors', 'On');
The result are the following error-messages:
Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; moonPhase has a deprecated constructor in /homepages/9/d694096150/htdocs/zedekia/wetter/mt/template/scripts/functions.php on line 2169
Warning: session_start(): Cannot send session cookie - headers already sent by (output started at /homepages/9/d694096150/htdocs/zedekia/wetter/mt/template/scripts/functions.php:2169) in /homepages/9/d694096150/htdocs/zedekia/wetter/mt/template/admin/authorize.php on line 41
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /homepages/9/d694096150/htdocs/zedekia/wetter/mt/template/scripts/functions.php:2169) in /homepages/9/d694096150/htdocs/zedekia/wetter/mt/template/admin/authorize.php on line 41
Warning: Cannot modify header information - headers already sent by (output started at /homepages/9/d694096150/htdocs/zedekia/wetter/mt/template/scripts/functions.php:2169) in /homepages/9/d694096150/htdocs/zedekia/wetter/mt/template/admin/authorize.php on line 111
I have also modified the php.ini like this:
zlib.output_compression=1
zlib.output_compression_level=9
error_reporting = E_ALL & ~E_NOTICE | E_DEPRECATED
display_errors = Off
display_startup_errors = Off
log_errors = On
log_errors_max_len = 1024
ignore_repeated_errors = Off
ignore_repeated_source = Off
report_memleaks = On
allow_url_fopen = On
track_errors = Off
xmlrpc_errors = 0
html_errors = Off
error_log = php-error.log
register_globals = on
allow_url_fopen = on
allow_url_include = on
No results.
The "master" Jachym is already concerned about the problem.
Best Regards (and sorry for my broken English)
Alexander
log_errors = On
track_errors = Off
xmlrpc_errors = 0
html_errors = Off
No results.
Alexander
Re: PHP 7.1.8 and 1&1
Hi Alex
the errors you see are fine, the first is a notice (irrelevant to this issue), the following errors are due to this notice being displayed. It really is a mystery to me. I was looking at your page again, but it just doesn´t show any errors and ends up with a blank page.
Do you have access to error log?
Btw. I use PHP 7.1 too, so it should not be an issue
- Zedekia
Hello Jachym,
Problem solved. I make a clean-install. Great. PHP 7.1 is so fast.......
Thank you Jachym.
Alex.
Thank you Jachym.
Alex.
Great
Yes, PHP 7+ is about twice as fast compared to PHP 5.x.
It is also easier for programmers to do certain things, but unfortunately this is something I cannot use because it would not work on 5.x servers.
- scadie
- Language Admin
- Station model: Davis Vantage Pro
I like this new forum, following your discussion, I check my hosting and see running PHP 5.6... I change it to 7.0 and run really much faster......
- Didiersm
- Station model: WMR200
- Software: Weathe rDisplay
I have changed my PHP version from 5.6 to 7 too... waouuu as faster is it compare to the 5.6.
Thanks Jachym for this tips, really usefull
Station WMR200
Fontenilles Wheather - FR http://didiersm.16mb.com/template/indexDesktop.php
mailto:didier.sm@gmail.com
- Johnny
- Developer
I've just updated mine as well - great tip.
- John B
What a difference!
I too have changed from 5.XX to 7.1 and am most pleased with the performance (relatively speaking, of course). It had never occurred to me that shifting to a later version of PHP would make such a difference.
Thanks to all for bringing the subject to our attention.
Cheers,
Cheers,
Thanks for letting me know, this means the person who had problems with 7.1.8 must have some missing parts of PHP. I have seen this with one other user before, where some functions which should normally be available were not installed.
