Server check error - url_fopen The url_fopen property is disabled ....
i_fiorentino
Post by i_fiorentino » Fri Jan 12, 2018 6:03 pm
Hi Jachym,
i'm installing a new copy of meteotemplate on this new domain: http://www.meteoponsacco.it
Once i've pushed "Server check" i've this error:
url_fopen
The url_fopen property is disabled in your PHP settings file. This needs to be enabled in order to be able to read files.
Do you know how to fix this in my host cpanel?
Thank you so much.
Alessandro
jay_hoehn
Software: WeeWx
Re: Server check error - url_fopen The url_fopen property is disabled ....
Post by jay_hoehn » Fri Jan 12, 2018 6:27 pm
Alessandro,
On your server you should find a file called php.ini. in that file there is a line that reads allow_url_fopen = off. Change the off to on and save the file. That should take care of the problem.
Jay
John B
Post by John B » Sat Jan 13, 2018 12:22 am
Allesandro,
If you are using C-Panel: Go to "Software" and select "Select PHP Version". Once that appears look to the top right. You should see an option "Switch to PHP Options". Click on that and you will see a list. The very first one is the option to turn on and off the "allow_url_fopen switch".
i_fiorentino
Post by i_fiorentino » Sat Jan 13, 2018 2:54 pm
Thanks for reply!
I've followed your instructions but i've this error:
Warning: Changing php modules and php options via PHP Selector for native php version is impossible
Any ideas?
Thanks in advance.
Alessandro
jay_hoehn
Software: WeeWx
Post by jay_hoehn » Sat Jan 13, 2018 4:10 pm
This sounds like your host doesn't allow allow_url_fopen = on. Call them and ask.
Jay
i_fiorentino
Post by i_fiorentino » Sat Jan 13, 2018 6:04 pm
jay_hoehn wrote: Sat Jan 13, 2018 4:10 pm This sounds like your host doesn't allow allow_url_fopen = on. Call them and ask.
Jay
Ok, thank you so much.
Alessandro
hankster
Station model: Weather Flow
Post by hankster » Sat Jan 13, 2018 6:44 pm
Try this. In the directory you have Meteotemplate installed upload a file named .user.ini (dot user dot ini) It should be uploaded as a text file (ascii)
In the file should be
allow_url_fopen = On
Post by Jachym » Sat Jan 13, 2018 8:15 pm
Thanks guys for helping out
i_fiorentino
Post by i_fiorentino » Sat Jan 13, 2018 8:18 pm
hankster wrote: Sat Jan 13, 2018 6:44 pm Try this. In the directory you have Meteotemplate installed upload a file named .user.ini (dot user dot ini) It should be uploaded as a text file (ascii)
Unfortunately i've the same error from server :(
Thanks anyway!
John B
Post by John B » Sat Jan 13, 2018 9:55 pm
Sorry, Alessandro, I have run out of ideas. Jay's suggestion to contact your site host and ask if they can turn on the switch seems to be your only option other than finding a new host.
Some free hosting sites do put some limitations on their customers, but I would have thought (I am no expert) that a paid-site host would have the option. Maybe I just got lucky (I had the same problem when installing Jáchym's masterpiece) with my choice of - cheap - host.
