Fix - Yearly Report (PDF) showing incorrect Max Temperature
Post by MonyMony » Thu Jan 02, 2020 12:35 pm
If you look at the Yearly Reports there is an option to generate a PDF version. While this is likely a feature that does not get used often, if you do run it you will notice that the Maximum Temperature shows 0.
Before Fix
Before Fix
Screen Shot 2020-01-02 at 7.27.06 AM.png (77.47 KiB) Viewed 5643 times
To correct this open the file reportYearlyPDF.php (found under the ../pages/station directory) and around line 503 look for this line:
<strong>'.number_format(convertT($data['monthlyMaxTmax']),1).'</strong>
Edit that line so that is becomes this:
<strong>'.number_format(convertT($data['annualMaxTmax']),1).'</strong>
The problem is the variable being called was listed incorrectly and needs to be changed to 'annualMaxTmax'. Once that is done and saved to your site the PDF yearly summary will work correctly.
After fix
After fix
Screen Shot 2020-01-02 at 7.34.18 AM.png (78.67 KiB) Viewed 5643 times
Hope this is useful to some of you!
Jolumarali
Station model: Vantage Vue
Software: WlIP
Re: Fix - Yearly Report (PDF) showing incorrect Max Temperature
Post by Jolumarali » Thu Jan 02, 2020 3:22 pm
Perfect, I found the error without ever solving it.
thanks and best wishes 2020
Michael
Station model: TE923
Software: WEEWX
Post by Michael » Sun Jan 12, 2020 10:57 am
I have another problem in yearly report.
In Tab Summary the warmest day in year was 25.07.2019 with temperatur max. 38,7 °C.
In Tab Extrema the warmest day in year was 25.07.2019 with temperatur 28,93 °C.
The same problem with coldest day.....
s. Attachment
Michael
Michael
Jolumarali
Software: WlIP
Post by Jolumarali » Sun Jan 12, 2020 12:33 pm
Hello
These are the coldest and warmest days at average temperatures in Extremes
