The world extreme plug Small Maps
Edderton_Weather
Station model: Davis Vantage PRO2
Post by Edderton_Weather » Mon Dec 04, 2017 9:19 pm
Hi I seem to have another problem
The world extreme plug just has a very small map which I can not make any bigger.
Just copied over to /plugin folder and used default setting nothing changed?
Any Ideas ?
Many thanks
Phillip
olav
Re: The world extreme plug Small Maps
Post by olav » Sat Dec 16, 2017 6:32 pm
The same happen to me. Tried to install it today, but just a very tiny map shows up.
Edit: For me it happen when using Chrome. I also tried with IE, and there it was okay.
Kind regards
Olav Krogsæter
Norway
http://www.sotraveret.no
Post by Jachym » Sat Dec 16, 2017 6:42 pm
Link please
olav
Post by olav » Sat Dec 16, 2017 6:50 pm
Kind regards
Olav Krogsæter
Norway
Post by Jachym » Sat Dec 16, 2017 9:46 pm
Hmm. This is what I see
olav
Post by olav » Sat Dec 16, 2017 10:22 pm
I also see the correct map if I use Internet Explorer, but just a tiny, tiny map if I use Google Chrome. Probably not easy to figure out what is happening, but at least two of us have the same issue.
Kind regards
Olav Krogsæter
Norway
meteocaldas
Station model: OS WMR-88A
Post by meteocaldas » Sat Dec 16, 2017 11:40 pm
olav wrote: Sat Dec 16, 2017 10:22 pm I also see the correct map if I use Internet Explorer, but just a tiny, tiny map if I use Google Chrome. Probably not easy to figure out what is happening, but at least two of us have the same issue.
Three of us ;)
John B
Post by John B » Sun Dec 17, 2017 12:32 am
It is looking like a browser compatibility matter. From my checks:
Edge - Yes
IE - Yes
FF - No
Safari - Yes, but squished
Opera- Yes
Maxthon - Yes
Chrome - No
Where 'Yes' = full map 'No' = Tiny map
Post by Jachym » Sun Dec 17, 2017 10:34 am
Interesting, I use Chrome almost exclusively and I see the entire map and no errors in the console. I also tried FF and no problems.
Strange, try CTRL+F5, that should reset the cache
olav
Post by olav » Sun Dec 17, 2017 1:33 pm
CTRL+F5 didn't work. But what is also interesting is that if I go to your site Jachym, and click on the World Extremes plugin, then it is working as it should, even though I'm using Chrome, but it is not working on my site.
Kind regards
Olav Krogsæter
Norway
Post by meteoesine » Sun Dec 17, 2017 2:04 pm
the same trouble also from my site.
I'm using Chrome too, no change after reset the cache and I see Jachim's plugin correctly
Post by Jachym » Sun Dec 17, 2017 4:25 pm
Mystery... I see it fine in Chrome on mine and your site...
Post by meteoesine » Sun Dec 17, 2017 4:45 pm
yes, very strange
I saw several other sites... the only fine is your
Post by Jachym » Sun Dec 17, 2017 7:49 pm
I use the exact same script...
:!: :?: :ugeek: :geek: :twisted: :shock: :shock: :shock: :lol: :?: :!: :ugeek: :ugeek: :shock: :shock: :shock:
Post by Jachym » Sun Dec 17, 2017 7:50 pm
The main problem is that I see it ok even on your site, so there is no way I can try to find the problem. For me there is none
hankster
Station model: Weather Flow
Post by hankster » Sun Dec 17, 2017 8:09 pm
For me on a Mac with Safari it is OK. With Chrome it is small.
