plugin camera images folder
androroz
Station model: WS-2310 11STWC
Post by androroz » Sat Jun 05, 2021 8:02 am
I ask for advice. Unable to transfer the video capture file from the camera to the plugin images folder. The ftp test file is generated in the folder before the public_html directory, and does not go further to the webcam plugin.
73!
Jolumarali
Station model: Vantage Vue
Software: WlIP
Re: plugin camera images folder
Post by Jolumarali » Sat Jun 05, 2021 5:29 pm
You must place the link of your image in the configuration of your plugin and then create a cron (See wiki)
could you put the link of your site.
please
Post by davidefa » Sat Jun 05, 2021 6:05 pm
As José Luis said, once you have the image on a folder on your server you are ok.
Then you have to use the address/url of the photo in the configuration of the block/plugin.
I suggest you starting from the block and once the block configuration is ok proceed to the plugin configuration
androroz
Post by androroz » Sun Jun 06, 2021 6:56 am
Good afternoon David! Again you are helping me, thank you. With the camera block it does not work with the plugin too. First, tell me why the block does not work. Soft BlueIris5. See screenshots.
webcam setting.png (177.54 KiB) Viewed 9433 times
meteocam folder.png (161.49 KiB) Viewed 9433 times
Jolumarali
Software: WlIP
Post by Jolumarali » Sun Jun 06, 2021 7:28 am
Try to place your webcam image in the template directory
http://www.dragana.lviv.in/template/meteocam/cam.jpg
your link is dead
http://www.dragana.lviv.in/meteocam/cam.jpg
androroz
Post by androroz » Sun Jun 06, 2021 10:10 am
Thanks for the answer. I create the path / template / meteocam / and the meteocam folder, but the .jpg file does not go into it inside public_html, but two folders are formed before public_html and the .jpg file is placed in them.
androroz
Post by androroz » Sat Jun 12, 2021 3:17 pm
I found the correct path through the / domains / directory for the .jpg file The block and plugin webcams are working !!!
/domains/dragana.lviv.in/public_html/template/plugins/webcam/images/
Jolumarali
Software: WlIP
Post by Jolumarali » Sun Jun 13, 2021 6:18 am
Hello
in fact the path of your image and this one.
for the plugin, you have to set up a Cron
http://www.dragana.lviv.in/template/hom ... am/cam.jpg
Good Sunday
