updated meteogram block
ver 3.2a
Updated the block to support the new api 2.0 of yr.no
Location specification changed: you have to specify latitude, longitude and altitude ( using following format: lat=xxx&lon=yyy&altitude=zzz )
Added option to show forecast with 1h resolution ( 2.5 days ) or 6h resolution ( 10 days ), option 'all' shows a mix of both
Added option to align sun/clouds icons on top of chart or 'along temperature line'
ver 3.2b
- corrected precipitation and icons representation
ver 3.2c
- restored wind speed indication in arrow
ver 3.2d
- time converted in local time ( it was utc )
ver 3.7 2024/12/09
- updated block as tooltip didn't work anymore
NOTE
Clear cache after updating parameters.
ver 3.2b
ver 3.2c
ver 3.2d
ver 3.7 2024/12/09
NOTE
- meteogram_3.7a.zip
- (760.64 KiB) Downloaded 829 times
- meteogram_3.2d.zip
- (719.34 KiB) Downloaded 1443 times
- meteogram_3.2c.zip
- (719.28 KiB) Downloaded 1407 times
- meteolopik
- Station model: Davis Pro 2 Plus
Re: updated meteogram block
ver 3.3
This version has a wind speed spline ( with superimposed wind direction arrow )
Height configurable in setup ( as % )
ver 3.3a
Time converted in local time ( it was utc )
ver 3.3a
- meteogram_3.3.zip
- (719.5 KiB) Downloaded 1216 times
- meteogram.png (104.3 KiB) Viewed 74556 times
- magical46
Hi, I noticed when using the original meteogram it recently was saying "failed to load data from external source. So I have updated to this latest version, I have put the co-ordinates in as
My site is www.philsweather.co.uk
any help much appreciated.
I don't think its connected to this issue but the GFS block is not showing any data either.
Phil
however now it is just saying "loading data from external source and whirring away without coming up with any data.Farnham,lat=51.2339&lon=-0.7795&altitude=90
Phil
I see your site is ok now ( when changing block's settings always clear the cache, otherwise you'll continue to see the previously cached data, untill the cache expires, tipicaly 1 hour ).
For the gfs block update to the latest version ( gfs_2.4 ), it should be already fixed
- Meteopomezia
- Software: Wview
Grande davide ottimo lavoro,
Ti volevo chiedere una cosa,su lato sx del meteogramme non si legge bene che devo modificare? guarda
https://www.meteopomezia.it
Poi un ultima cosa anche se e una domanda out,
per avere il template a tutto schermo come il tuo cosa devo modificare?
Dove di preciso, a cosa ti riferisci?
Mi ci vuole un po' per capire, sarà... a volte l'ultima label della scala velocità si sovrappone con la prima label della scala temperature ( cosa che nella immagine non succede ), intendi questo?
P.S. Are you referring to the fact that sometime ( not in the attached image ) the last label of the wind speed scale overlaps with the first label of the temperature scale?
Per eliminare la scroll bar orizontale ho diminuito la 'custom page width' nel setup iniziale ( oppure puoi modificare la variabile $customMaxWidth intorno alla riga 161 in config.php, che è la stessa cosa ), l'ho diminuita finchè non è scomparsa
To remove the horizontal scroll bar I reduced the 'custom page width' in the initial setup ( you can do the exact same thing modifying variable $customMaxWidth near line 161 in config.php ), I reduced till the scroll bar disappeared
- Meteopomezia
- Software: Wview
A questo guarda immagine sulla destradavidefa wrote: ↑Wed May 26, 2021 9:23 am Dove di preciso, a cosa ti riferisci?
ver 3.3b
Minor update: added option to define a separation between Temperature and Wind graphs ( so labels do not overlap )
ver 3.3c
Corrected the offset of the wind arrows ( introduced in ver 3.3b )
ver 3.3c
- meteogram_3.3c.zip
- (760.73 KiB) Downloaded 1401 times
- meteogram_3.3b.zip
- (760.73 KiB) Downloaded 1217 times
- Meteopomezia
- Software: Wview
Good evening Davide solved the problem of the display on the right side.Meteopomezia wrote: ↑Tue Jun 01, 2021 7:17 pmA questo guarda immagine sulla destradavidefa wrote: ↑Wed May 26, 2021 9:23 am Dove di preciso, a cosa ti riferisci?
at line 323 increased marginRight: from 40 to 50 and now it looks good ..
- Daali
- Station model: Ecowitt GW1002
- Software: Meteobridge, FOSHKplugin
I've gone thru and verified the url's in the browser
https://api.met.no/weatherapi/locationf ... titude=267
but debugging(always tough with php) it looks like this like does not populate with the '.$meteogramIDs[$locationID] which I can see has data in the variable $meteogramLocations but gets lost in the explode(maybe a debug issue on my part)
Is the meteogram working for everyone else? There may be something else wrong in my config or settings throwing it off.
$yrNoLocation = 'https://api.met.no/weatherapi/locationforecast/2.0/compact?'.$meteogramIDs[$locationID][1];https://www.jeffersonweather.com
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
WH41 PM2.5 Air Quality
WH45 PM2.5/10/Co2 Air Quality
WN34S Soil temperature
WH31SM Soil Moisture
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
- tobydude
- Station model: Netatmo
- Software: Weatherdiaplay
Nice.
Just installed.
Is it possible to make the block so that users to change colors on temperature -line, pressure-line , and so on?
Just installed.
- Daali
tobydude,
it must be working since you asked about colors, which version did you select 3.3c?
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
@tobydude
Ok, I'll add color selection
@daali
This is my setting
note the comma between the location name and the coordinates ( without any spaces leading/trailing/between )
Could you check if it works for you or please post your configuration ( so I can check )
I'm using ver 3.3c ( the difference between ver 3.2 and ver 3.3 is the arrow wind position )
@daali
This is my setting
Fano-Italy,lat=43.84052&lon=13.01665&altitude=12Could you check if it works for you or please post your configuration ( so I can check )
- Daali
Arcade,lat=34.07789&lon=-83.56155&altitude=267 is mine that just spins. Using your data just spins as well.
I'll purged the block directory, re-downloaded 3.3c, and tried again. still no luck with your settings. I wonder if my system using https is affecting it.
Thanks guys!
Thanks guys!
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
Forgot to mention to clear cache after modifying the settings ( or you'll continue to see the previously cached data until cache expires, generally 1h, giving you the impression that every change you make has no result )
Your settings should be similar to this
and the result should be similar to this
- Daali
do you mean browser cache or the cache directory? nothing is populating in my cache directory of the block
I've verified the meteogram/cache folder is set to 755, still, nothing populates there.
My issue has to be something host-related, something simple. I've reset the folder to 0705(like others in the working block section), checked the owner. dataloader never populates the cache.
*went all the way back to original in thread: no data
*hacked up dataloader.php to be single site with no cache logic, pulled data! so Curl works.
*went back to original in thread: no data.
*reverted to http (from https): no data
*called dataloader (dataLoader.php?callback=?) and at least got 400 bad request
*called dataloader (https://www.jeffersonweather.com/homepa ... ack=?&id=0) and got data back.
*changed from http to https, called dataloader
I cannot really debug it on the hosted server, it has to be something silly, just doesn't seem like the parameters are being passed to dataloader.php
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
Joesab
- Station model: Davis Pro V2
- Software: weewx
bonjour à tous
gfs fonctionne
par contre meteogramme non,
je ne comprends pas ce qu'il faut que je rentres comme ligne de paramétrage...
merci pour les explications
sabine
édit : c'est ok, ça marche
merci pour le boulot que vous faites !
gfs fonctionne
sabine
You should enter something like this: Bailleval,lat=49.34976&lon=2.44068&altitude=156
In the firefox error console there is an error when the block is loaded.Daali wrote: ↑Thu Aug 05, 2021 2:54 pm do you mean browser cache or the cache directory? nothing is populating in my cache directory of the block
Not sure how to debug this, but you may try to move the block outside the menuBlock of meteotemplate, and see if something change ( or at least a more meaningful error is returned )
- Daali
Thank you davidfa, but I probably caused that error while hacking away at it.
I've reverted back to your latest 3.3c. and you have led me to a new debugging path!
Found 3 missing "(" and ")" that were causing me issues in the math.round sections
original line 658:
changed line 658
original line 675:
changed line 675:
original line 713:
changed line 713:
image loads! hurray!!
original line 658:
echo "y: Math.round(element.data.next_6_hours.details.precipitation_amount)*0.0393701*100)/100";Code: Select all
echo "y: Math.round(((element.data.next_6_hours.details.precipitation_amount)*0.0393701*100)/100)";Code: Select all
echo "y: Math.round(element.data.next_1_hours.details.precipitation_amount)*0.0393701*100)/100";Code: Select all
echo "y: Math.round(((element.data.next_1_hours.details.precipitation_amount)*0.0393701*100)/100)";Code: Select all
echo "y: Math.round(parseFloat(element.data.instant.details.air_pressure_at_sea_level)*0.0295299830714*100)/100";Code: Select all
echo "y: Math.round((parseFloat(element.data.instant.details.air_pressure_at_sea_level)*0.0295299830714*100)/100)";https://www.jeffersonweather.com
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
weatherbee
- Daali
Awesome! Looking at it I guess it only affected us "imperial" unit guys/gals =P Everyone else was working fine!
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
kd7eir
- Station model: Ecowitt Wittboy
- Software: FOSHKplugin
This fixed the block for me, thank you!Daali wrote: ↑Mon Aug 09, 2021 12:07 am Thank you davidfa, but I probably caused that error while hacking away at it.
original line 658:changed line 658Code: Select all
echo "y: Math.round(element.data.next_6_hours.details.precipitation_amount)*0.0393701*100)/100";original line 675:Code: Select all
echo "y: Math.round(((element.data.next_6_hours.details.precipitation_amount)*0.0393701*100)/100)";changed line 675:Code: Select all
echo "y: Math.round(element.data.next_1_hours.details.precipitation_amount)*0.0393701*100)/100";original line 713:Code: Select all
echo "y: Math.round(((element.data.next_1_hours.details.precipitation_amount)*0.0393701*100)/100)";changed line 713:Code: Select all
echo "y: Math.round(parseFloat(element.data.instant.details.air_pressure_at_sea_level)*0.0295299830714*100)/100";image loads! hurray!!Code: Select all
