updated meteogram block
Post by davidefa » Fri Apr 09, 2021 10:21 pm
ver 3.2a
Updated the block to support the new api 2.0 of yr.no
Location specification changed: you have to specify latitude, longitude and altitude ( using following format: lat=xxx&lon=yyy&altitude=zzz )
Added option to show forecast with 1h resolution ( 2.5 days ) or 6h resolution ( 10 days ), option 'all' shows a mix of both
Added option to align sun/clouds icons on top of chart or 'along temperature line'
ver 3.2b
- corrected precipitation and icons representation
ver 3.2c
- restored wind speed indication in arrow
ver 3.2d
- time converted in local time ( it was utc )
ver 3.7 2024/12/09
- updated block as tooltip didn't work anymore
NOTE
Clear cache after updating parameters.
meteogram_3.7a.zip
(760.64 KiB) Downloaded 825 times
meteogram_3.2d.zip
(719.34 KiB) Downloaded 1442 times
meteogram_3.2c.zip
(719.28 KiB) Downloaded 1406 times
meteolopik
Re: updated meteogram block
Post by meteolopik » Mon Apr 12, 2021 10:22 am
Installed latest version and works just perfectly, Much appreciated!
Post by davidefa » Mon Apr 12, 2021 7:34 pm
ver 3.3
This version has a wind speed spline ( with superimposed wind direction arrow )
Height configurable in setup ( as % )
ver 3.3a
Time converted in local time ( it was utc )
meteogram_3.3a.zip
(719.63 KiB) Downloaded 1603 times
meteogram_3.3.zip
(719.5 KiB) Downloaded 1215 times
magical46
Post by magical46 » Wed Apr 28, 2021 9:07 am
Hi, I noticed when using the original meteogram it recently was saying "failed to load data from external source. So I have updated to this latest version, I have put the co-ordinates in as
Farnham,lat=51.2339&lon=-0.7795&altitude=90
however now it is just saying "loading data from external source and whirring away without coming up with any data.
My site is www.philsweather.co.uk
any help much appreciated.
I don't think its connected to this issue but the GFS block is not showing any data either.
Phil
Post by davidefa » Wed Apr 28, 2021 10:58 am
I see your site is ok now ( when changing block's settings always clear the cache, otherwise you'll continue to see the previously cached data, untill the cache expires, tipicaly 1 hour ).
For the gfs block update to the latest version ( gfs_2.4 ), it should be already fixed
Meteopomezia
Software: Wview
Post by Meteopomezia » Tue May 25, 2021 8:17 pm
Grande davide ottimo lavoro,
Ti volevo chiedere una cosa,su lato sx del meteogramme non si legge bene che devo modificare? guarda :D
https://www.meteopomezia.it
Poi un ultima cosa anche se e una domanda out,
per avere il template a tutto schermo come il tuo cosa devo modificare? :D :D :D
Post by davidefa » Wed May 26, 2021 9:23 am
Dove di preciso, a cosa ti riferisci?
Mi ci vuole un po' per capire, sarà... a volte l'ultima label della scala velocità si sovrappone con la prima label della scala temperature ( cosa che nella immagine non succede ), intendi questo?
P.S. Are you referring to the fact that sometime ( not in the attached image ) the last label of the wind speed scale overlaps with the first label of the temperature scale?
Per eliminare la scroll bar orizontale ho diminuito la 'custom page width' nel setup iniziale ( oppure puoi modificare la variabile $customMaxWidth intorno alla riga 161 in config.php, che è la stessa cosa ), l'ho diminuita finchè non è scomparsa
To remove the horizontal scroll bar I reduced the 'custom page width' in the initial setup ( you can do the exact same thing modifying variable $customMaxWidth near line 161 in config.php ), I reduced till the scroll bar disappeared
Meteopomezia
Software: Wview
Post by Meteopomezia » Tue Jun 01, 2021 7:17 pm
davidefa wrote: Wed May 26, 2021 9:23 am Dove di preciso, a cosa ti riferisci?
Schermata del 2021-06-01 21-14-17.png (785.19 KiB) Viewed 74022 times
A questo guarda immagine sulla destra
Post by davidefa » Wed Jun 02, 2021 1:39 pm
ver 3.3b
Minor update: added option to define a separation between Temperature and Wind graphs ( so labels do not overlap )
ver 3.3c
Corrected the offset of the wind arrows ( introduced in ver 3.3b )
meteogram_3.3c.zip
(760.73 KiB) Downloaded 1400 times
meteogram_3.3b.zip
(760.73 KiB) Downloaded 1217 times
Meteopomezia
Software: Wview
Post by Meteopomezia » Sun Jun 06, 2021 7:43 pm
Meteopomezia wrote: Tue Jun 01, 2021 7:17 pm
Good evening Davide solved the problem of the display on the right side.
at line 323 increased marginRight: from 40 to 50 and now it looks good ..
Daali
Station model: Ecowitt GW1002
Post by Daali » Wed Aug 04, 2021 5:55 pm
I've gone thru and verified the url's in the browser
https://api.met.no/weatherapi/locationf ... titude=267
but debugging(always tough with php) it looks like this like does not populate with the '.$meteogramIDs[$locationID] which I can see has data in the variable $meteogramLocations but gets lost in the explode(maybe a debug issue on my part)
$yrNoLocation = 'https://api.met.no/weatherapi/locationforecast/2.0/compact?'.$meteogramIDs[$locationID][1];
Is the meteogram working for everyone else? There may be something else wrong in my config or settings throwing it off.
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
WH41 PM2.5 Air Quality
WH45 PM2.5/10/Co2 Air Quality
WN34S Soil temperature
WH31SM Soil Moisture
tobydude
Software: Weatherdiaplay
Post by tobydude » Thu Aug 05, 2021 12:10 pm
Nice.
Just installed.
Is it possible to make the block so that users to change colors on temperature -line, pressure-line , and so on?
Daali
Post by Daali » Thu Aug 05, 2021 12:46 pm
tobydude,
it must be working since you asked about colors, which version did you select 3.3c?
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
tobydude
Post by tobydude » Thu Aug 05, 2021 1:04 pm
3d
Post by davidefa » Thu Aug 05, 2021 1:59 pm
@tobydude
Ok, I'll add color selection
@daali
This is my setting
Fano-Italy,lat=43.84052&lon=13.01665&altitude=12
note the comma between the location name and the coordinates ( without any spaces leading/trailing/between )
Could you check if it works for you or please post your configuration ( so I can check )
I'm using ver 3.3c ( the difference between ver 3.2 and ver 3.3 is the arrow wind position )
Daali
Post by Daali » Thu Aug 05, 2021 2:29 pm
Arcade,lat=34.07789&lon=-83.56155&altitude=267 is mine that just spins. Using your data just spins as well.
I'll purged the block directory, re-downloaded 3.3c, and tried again. still no luck with your settings. I wonder if my system using https is affecting it.
Thanks guys!
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
Post by davidefa » Thu Aug 05, 2021 2:48 pm
Forgot to mention to clear cache after modifying the settings ( or you'll continue to see the previously cached data until cache expires, generally 1h, giving you the impression that every change you make has no result )
Your settings should be similar to this
and the result should be similar to this
Daali
Post by Daali » Thu Aug 05, 2021 2:54 pm
do you mean browser cache or the cache directory? nothing is populating in my cache directory of the block
I've verified the meteogram/cache folder is set to 755, still, nothing populates there.
My issue has to be something host-related, something simple. I've reset the folder to 0705(like others in the working block section), checked the owner. dataloader never populates the cache.
*went all the way back to original in thread: no data
*hacked up dataloader.php to be single site with no cache logic, pulled data! so Curl works.
*went back to original in thread: no data.
*reverted to http (from https): no data
*called dataloader (dataLoader.php?callback=?) and at least got 400 bad request
*called dataloader (https://www.jeffersonweather.com/homepa ... ack=?&id=0) and got data back.
*changed from http to https, called dataloader
I cannot really debug it on the hosted server, it has to be something silly, just doesn't seem like the parameters are being passed to dataloader.php
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
Joesab
Station model: Davis Pro V2
Software: weewx
Post by Joesab » Sun Aug 08, 2021 2:35 pm
bonjour à tous
gfs fonctionne
par contre meteogramme non,
je ne comprends pas ce qu'il faut que je rentres comme ligne de paramétrage... :cry:
merci pour les explications
sabine
édit : c'est ok, ça marche
merci pour le boulot que vous faites !
Post by davidefa » Sun Aug 08, 2021 9:00 pm
Joesab wrote: Sun Aug 08, 2021 2:35 pm bonjour à tous
gfs fonctionne
sabine
You should enter something like this: Bailleval,lat=49.34976&lon=2.44068&altitude=156
Post by davidefa » Sun Aug 08, 2021 9:10 pm
Daali wrote: Thu Aug 05, 2021 2:54 pm do you mean browser cache or the cache directory? nothing is populating in my cache directory of the block
In the firefox error console there is an error when the block is loaded.
Not sure how to debug this, but you may try to move the block outside the menuBlock of meteotemplate, and see if something change ( or at least a more meaningful error is returned )
Daali
Post by Daali » Mon Aug 09, 2021 12:07 am
Thank you davidfa, but I probably caused that error while hacking away at it.
I've reverted back to your latest 3.3c. and you have led me to a new debugging path!
Found 3 missing "(" and ")" that were causing me issues in the math.round sections
original line 658:
echo "y: Math.round(element.data.next_6_hours.details.precipitation_amount)*0.0393701*100)/100";
changed line 658
echo "y: Math.round(((element.data.next_6_hours.details.precipitation_amount)*0.0393701*100)/100)";
original line 675:
echo "y: Math.round(element.data.next_1_hours.details.precipitation_amount)*0.0393701*100)/100";
changed line 675:
echo "y: Math.round(((element.data.next_1_hours.details.precipitation_amount)*0.0393701*100)/100)";
original line 713:
echo "y: Math.round(parseFloat(element.data.instant.details.air_pressure_at_sea_level)*0.0295299830714*100)/100";
changed line 713:
echo "y: Math.round((parseFloat(element.data.instant.details.air_pressure_at_sea_level)*0.0295299830714*100)/100)";
image loads! hurray!!
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
weatherbee
Post by weatherbee » Mon Aug 09, 2021 4:01 pm
Daali,
Thanks for posting your changes. It fixed mine too.
Daali
Post by Daali » Mon Aug 09, 2021 5:19 pm
Awesome! Looking at it I guess it only affected us "imperial" unit guys/gals =P Everyone else was working fine!
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
kd7eir
Station model: Ecowitt Wittboy
Software: FOSHKplugin
Post by kd7eir » Tue Aug 10, 2021 8:24 am
Daali wrote: Mon Aug 09, 2021 12:07 am Thank you davidfa, but I probably caused that error while hacking away at it.
original line 658:
changed line 658
original line 675:
changed line 675:
original line 713:
changed line 713:
This fixed the block for me, thank you!
