Database update / WU / failed cron-job
dtwrlewis
Station model: Ecowitt HP2553
Software: Ecowitt GW1100
Post by dtwrlewis » Sun Nov 07, 2021 3:26 pm
Having intermittent problems here http://www.dtwrlewis.com/radlett/indexDesktop.php. Database updates via WU IENGLAND417 - updated the WU APIKey - updated Meteotemplate to 18. It worked for 12 hrs then failed today. Strangely, even tho cron-job history says it failed at each attempt today - the home page seems to be occasionally updating with current data. Any ideas
Screen Shot 2021-11-07 at 11.07.34 AM.png (342.9 KiB) Viewed 11527 times
dtwrlewis
Re: Database update / WU / failed cron-job
Post by dtwrlewis » Mon Nov 08, 2021 2:32 pm
JUst an update on this - my template stopped updating at 8.30 local time. All subsequent cron-job report fail. However the current conditions block is somehow still working. Wondering if I need to do a fresh instal? This is for my dad's weather station. Mine is on the same server ..../rothesay and updates via weathercat api - no problems
Post by davidefa » Mon Nov 08, 2021 10:02 pm
From your cache/updateLog.txt e cache/updateLog.txt I see that your cron job is sometime working ( 17:40, 21:30 and 21:46 ).
On my test pc I have no problem retrieving your data from wu using your station id and api key.
So I think the problem lies ( somehow ) in the cron job.
To verify this try calling your update.php 'manually':
- from your browser go to the page: http://www.dtwrlewis.com/radlett/update ... sword=xxxx ( substitute xxxx with your update password ), this should not timeout
- in cache/apiLog.txt you should see a long log starting with something similar to this
Handling data from wu
update 'SW' = wu
update 'U' = 1636407011 (2021-11-08 21:30:11)
update 'T' = 10.5
update 'H' = 97
update 'P' = 1020.32
update 'W' = 0
update 'G' = 8
update 'R' = 0.25
update 'RR' = 0
update 'B' = 173
update 'S' =
- wait 5 minutes repeat the above points a couple times
If everything works as expected try disabling the original cron job and set a new one ( you could use also a free cron job from https://cron-job.org/en/ just for testing )
Even if wu is now working ok, we don't know if this morning wu had 'a few hiccups' ( not very difficult to believe ) and the cron job gave up after repeated errors (check if you cron job has a detailed log of the failures )
dtwrlewis
Post by dtwrlewis » Thu Nov 11, 2021 10:25 pm
Thanks davidefa. When I call the update.php manually it takes forever (2-4mins) to result in "success' page.
It seem to be a problem with the update.php
update 'SW' = wu
update 'U' = 1636668612 (2021-11-11 22:10:12)
update 'T' = 8
update 'H' = 96
update 'P' = 1017.27
update 'W' = 0
update 'G' = 0
update 'R' = 0
update 'RR' = 0
update 'B' = 147
update 'S' =
Start handling live data
Extra sensor settings file not found.
Extra sensors data to save in db:
add live data: S:
add live data: D: 7.5
add live data: DTime: 1636668568
add live data: A: 7.5
add live data: ATime: 1636668568
calculated D: 7.4
calculated A: 7.4
Save meteotemplateLive.txt: {"SW":"wu","U":1636668612,"T":8,"H":96,"P":1017.26999999999998181010596454143524169921875,"W":0,"G":0,"R":0,"RR":0,"B":147,"S":null,"SWTime":1636668961,"UTime":1636668961,"TTime":1636668961,"HTime":1636668961,"PTime":1636668961,"WTime":1636668961,"GTime":1636668961,"RTime":1636668961,"RRTime":1636668961,"BTime":1636668961,"STime":1636668961,"D":7.4000000000000003552713678800500929355621337890625,"DTime":1636668961,"A":7.4000000000000003552713678800500929355621337890625,"ATime":1636668961}
Post by davidefa » Fri Nov 12, 2021 6:31 pm
To verify what is taking so long yo can substitute your update/update.php script with the attached one ( make a backup of the original script ), only added a few extra print to show the timing.
The script tries to retrieve data from wu in two different ways, maybe the call to file_get_contents on line 246 times out.
Call the script 'manually' as you already did, at the end you can find an extended log in cache/updateLog.txt.
update.zip
(3.74 KiB) Downloaded 576 times
dtwrlewis
Post by dtwrlewis » Sat Nov 13, 2021 2:53 pm
Thank you again davidefa.
Current date/time: 2021-11-13 14:46:33
Loading data from https://api.weather.com/v2/pws/observat ... on=decimal
Calling file_get_contents: 2021-11-13 14:46:33
Exiting file_get_contents:2021-11-13 14:47:33
Calling curlMain: 2021-11-13 14:47:33
Exiting curlMain: 2021-11-13 14:47:33
Loaded data items from WU = {"observations":[{"stationID":"IENGLAND417","obsTimeUtc":"2021-11-13T14:45:34Z","obsTimeLocal":"2021-11-13 14:45:34","neighborhood":"Radlett","softwareType":"weatherlink.com 1.10","country":"GB","solarRadiation":null,"lon":-0.318778,"realtimeFrequency":null,"epoch":1636814734,"lat":51.677654,"uv":null,"winddir":329,"humidity":82.0,"qcStatus":1,"metric":{"temp":11.8,"heatIndex":11.8,"dewpt":8.9,"windChill":11.8,"windSpeed":1.6,"windGust":12.9,"pressure":1014.56,"precipRate":0.00,"precipTotal":0.00,"elev":100.0}}]}
Calling api.php date/time: 2021-11-13 14:47:33
Success
Exiting api.php date/time: 2021-11-13 14:47:33
updateLog.txt.zip
(1.18 KiB) Downloaded 602 times
Post by davidefa » Sun Nov 14, 2021 9:57 pm
It seems that the data are updated regularly now.
I removed the file_get_contents that times out after 1 min ( data are retrieved with curl ).
You can now revert your cron job to the original one every minute.
I uploaded a test file ( www.dtwrlewis.com/radlett/update/test0.php ) which uses file_get_content to retrieve the content of 2 sites:
- the first call result in a incomplete page
- the second call times out
For some reason this command file_get_contents is not working properly in your site ( you may contact your provider for a clue )
This means that blocks and plugins that use this command to access external sites do not ( or may not ) work properly.
For example the forecast block does not retrieves yr.no forecasts.
( but these blocks/plugins can be modified to work in your site )
dtwrlewis
Post by dtwrlewis » Tue Nov 16, 2021 7:15 pm
Thanks davidefa
My main concern is the station data. I can live without the external block for now. I really appreciate your help with solving the data update issue. :)
dtwrlewis
Post by dtwrlewis » Tue Nov 16, 2021 7:26 pm
PS - Noticed your site location. We have a small vacation property in a village called Farnocchia. We used to have a Vantage Vue running remotely over a few years. https://www.wunderground.com/dashboard/ ... 1-16/daily But the power supply and internet connection was so unreliable that we shut down the feed 2 years ago. Looking forward visiting Italy next year (Pandemic permitting!)
Post by davidefa » Tue Nov 16, 2021 8:47 pm
dtwrlewis wrote: Tue Nov 16, 2021 7:15 pm I can live without the external block for now.
Sorry, what do you mean by 'external block'?
dtwrlewis
Post by dtwrlewis » Tue Nov 16, 2021 8:50 pm
Blocks that access external sites e.g the yr.no forecast
