Updated weatherNetworks block
ver 7.1a
Added ecowit.net, ambientweather.net and windy.com
ver 7.2b
- added option to set NWS link
- Added option to select between two ecowitt logo
- added option to disable highlighting when cursor over icons ( always highlighted )
ver 7.2b
- weatherNetworks_7.2b.zip
- (694.79 KiB) Downloaded 589 times
- weatherNetworks_7.1a.zip
- (699.01 KiB) Downloaded 609 times
- Daali
Re: Updated weatherNetworks block
Thank you davidefa!
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
WH41 PM2.5 Air Quality
WH45 PM2.5/10/Co2 Air Quality
WN34S Soil temperature
WH31SM Soil Moisture
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
- amonphi
- Station model: Ecowitt GW1003
- Software: WU
Hi Davidefa,
I have just updated WeatherNetworks Block, I couldn't help but notice the addition of windy.com to the settings. I have been registered to their site for years and with their development in beta are a nice step forward finally. But now, as an Ecowitt PWS owner, the problem has arisen on how to load data to windy automatically. Can you tell me if it is possible through Meteotemplate? Because from App Ecowitt Wsview Plus, in the Weather Services options, Windy is not unfortunately present and I don't even know if it will ever. I seem to understand that the ECOWitt protocol is compatible even in customized. Is the solution compulsorily a raspberry pi or meteorebridge?
Yes, using the 'forwarders' of the ecowitt plugin.
For Windy:
In 'forward data format' select: WU
In 'forward server' set: ( substitute YOURAPIKEY with your api key ): https://stations.windy.com/pws/update/YOURAPIKEY
For PWS:
In ''forward data format' select: WU
In 'forward server' set: http://www.pwsweather.com/pwsupdate/pwsupdate.php
In forward id and password set your id and password
For WU:
In 'forward server' set: https://weatherstation.wunderground.com ... tation.php
For Windy:
For PWS:
For WU:
- windy.png (121.26 KiB) Viewed 13324 times
- amonphi
- Software: WU
But as I did not get there ... you really thought about everything, great.davidefa wrote: ↑Wed Jan 12, 2022 5:02 pm Yes, using the 'forwarders' of the ecowitt plugin.
For Windy:
For PWS:
For WU:
Now from Windy's link again reports "error loading or render station date", I assume it is due to the fact that there are few data but in a few hours I should see something, at most tomorrow.
- amonphi
- Software: WU
UPDATEdavidefa wrote: ↑Wed Jan 12, 2022 5:02 pm Yes, using the 'forwarders' of the ecowitt plugin.
For Windy:
I created Map Forecast API but, I still don't see anything unfortunately and I don't understand why. On the "Manage Your API Keys" page still reports "The Key Has Not Been Used Yet." And if I try to use the three "Get" methods to view the data
- https://stations.windy.com/pws/station/ ... station_id
- https://stations.windy.com/pws/stations/api-key
I always get "Invalid token".
Now I came to doubt if I entered the data in "create in New API Key" but I was very uncertain Sorry but sometimes I lose myself in nonsense
mchd17
any way i could change the url for NWS that goes to forecast to my NWS station info? Link below.
https://www.wrh.noaa.gov/mesowest/getob ... 710&num=48
weatherNetworksBlock.php, line 133 maybe
mchd17
Seems the NWS link now is tied to my Lat and Lon
current link
https://forecast.weather.gov/MapClick.p ... fCu5erMJPY
current link
mchd17
need to edit line 133 in the weatherNetworksBlock.php
line 133
to this, add in your nws site url
line 133
<a href="http://forecast.weather.gov/MapClick.php?textField1=<?php echo $stationLat?>&textField2=<?php echo $stationLon?>" target="_blank">Code: Select all
<a href="https://www.wrh.noaa.gov/your/site/url/" target="_blank">-
macipbarreda
- Station model: Fine offset
- Software: Cumulus MX
Hello Goodnight davidefa. I see that in the latest version of weatherNetworks block, the Meteoclimatic network is included. I suppose that this network will have to be configured in the ecowitt plugin in the Advanced Setting section in one of the Forward data format.
Could you comment on the data that must be put in URL, Port, User and Password? Thanks
Never tried, but according to these instructions:
- set protocol to WU
- set URL to http://meteoclimatic.atmos.cat/wu/index.php
- leave empty port
- set username the code of your weather station ( 'código de nuestra estación en Meteoclimatic' )
- set password 'la contraseña que habremos generado en el enlace del primer mensaje http://meteoclimatic.atmos.cat/alta (Nota: las contraseñas generadas sólo són válidas hasta las 0:00 UTC del día que se han generado si la estación no se configura para enviar datos. De ser así habrá que generar una nueva.) '
- leave empty port
macipbarreda
Thank you for all of your help. I think it's already uploading data
