graphic downloads in various image formats
Post by meteoesine » Sun Jan 23, 2022 4:40 pm
despite having https, I have noticed that I am no longer able to download graphics in various formats. I have tried both with chrome and with other browsers.
The problem must be on my side because I can easily download the graphics from other users.
The warning message is the following: The information you are about to send is not secure. As this form was submitted via an insecure connection, the information will be visible to others.
the current php version is 7.4
any idea?
thanks in advance
Re: graphic downloads in various image formats
Post by davidefa » Sun Jan 23, 2022 10:59 pm
You can try updating the highcharts scripts ( in the scripts directory ) with the attached ones.
Make a backup of the original ones.
This should solve the graphic conversion, unsure if it is 100% compatible with other plugins/blocks
highcharts v9.3.2.zip
(186.73 KiB) Downloaded 837 times
Post by meteoesine » Mon Jan 24, 2022 7:13 am
grazie Davide,
problema non risolto... pazienza
ciao
Post by davidefa » Mon Jan 24, 2022 7:47 am
Su quale pagina stai provando in particolare?
Post by meteoesine » Mon Jan 24, 2022 9:11 am
su tutti...
comunque a parte il fatto che non escono proprio benissimo anche scaricandoli dagli altri utenti, alla fine ho optato di disattivare il download dei grafici su tutte le pagine :D
<!---<script type="text/javascript" src="<?php echo $pageURL.$path?>scripts/exporting.js"></script>-->
chart (2).png (14.54 KiB) Viewed 4440 times
