despite having https, I have noticed that I am no longer able to download graphics in various formats. I have tried both with chrome and with other browsers.
The problem must be on my side because I can easily download the graphics from other users.
The warning message is the following: The information you are about to send is not secure. As this form was submitted via an insecure connection, the information will be visible to others.
the current php version is 7.4
any idea?
thanks in advance
graphic downloads in various image formats
- meteoesine
- Station model: Davis Pro2+
- Software: Meteobridge nano
- ScreenShot00937.jpg (6.13 KiB) Viewed 4459 times
- ScreenShot00938.jpg (18.53 KiB) Viewed 4459 times
- ScreenShot00936.jpg (28.2 KiB) Viewed 4459 times
Re: graphic downloads in various image formats
You can try updating the highcharts scripts ( in the scripts directory ) with the attached ones.
Make a backup of the original ones.
This should solve the graphic conversion, unsure if it is 100% compatible with other plugins/blocks
- highcharts v9.3.2.zip
- (186.73 KiB) Downloaded 838 times
- meteoesine
grazie Davide,
problema non risolto... pazienza
ciao
ciao
- meteoesine
su tutti...
comunque a parte il fatto che non escono proprio benissimo anche scaricandoli dagli altri utenti, alla fine ho optato di disattivare il download dei grafici su tutte le pagine
<!---<script type="text/javascript" src="<?php echo $pageURL.$path?>scripts/exporting.js"></script>-->
- chart.png (10.21 KiB) Viewed 4443 times
- chart (2).png (14.54 KiB) Viewed 4443 times
