Ecowitt plugin configuration
macipbarreda
Station model: Fine offset
Software: Cumulus MX
Post by macipbarreda » Sun Jan 23, 2022 3:31 pm
Hello, I recently bought an Ecowitt GW1100 to be able to eliminate the computer, in charge of uploading data from my weather station ( http://www.meteosantmateu.online/templa ... esktop.php ) to my website through the CumulusMX program.
After some failed attempts I have finally managed to upload the data to Meteotemplate.
With my old management program -CumulusMX- of the weather station, I was able to send data to Awekas https://www.awekas.at/es/instrument.php?id=10757, but now it is stuck with the latest data that I sent from CumulusMX and would like to be able to continue sending data.
I have uploaded two screenshots of my Ecowitt plugin configuration and Awekas configuration and I don't know where the problem is so that it doesn't update data in Awekas.
Any help is welcome. Thank
Re: Ecowitt plugin configuration
Post by davidefa » Sun Jan 23, 2022 6:07 pm
In 'Forwared server 1 url' set http://data.awekas.at/eingabe_pruefung.php
Leave empty 'Forward server 1 port'
To check for error/problems take a look at cache/ecowittLog.txt
macipbarreda
Post by macipbarreda » Mon Jan 24, 2022 3:26 pm
Hello davidfafa. It seems that thanks to your solution, my station sends data again https://www.awekas.at/en/instrument.php?id=17680#day. Attached capture with the changed data as well as the ecowittLog.txt file. Thanks
ACpower
Station model: Ecowit GW1100
Post by ACpower » Fri Apr 28, 2023 3:33 pm
I have the same problem, I configured everything as described but nothing arrives on the Awekas site, I also tried another configuration found on the Awekas forum but the result is the same.
Thanks for your help
Ale
Post by davidefa » Mon Oct 09, 2023 2:06 pm
Hy ACpower, I see your site is on altervista, did you enable 'Collegamento esterno senza restrizioni ' on the control panel of altervista?
Once it is ok check your cache/ecowittLog.txt file, at the end of the file you should have something similar to the last image.
The forwarder result should contain the response from the server:
- status should be 1 or 2
- authentication should be 1.
ACpower
Post by ACpower » Wed Oct 11, 2023 2:07 pm
Thank you Davide
I wll try and replay..
at the moment I updated to version 19 and I think I have other problems, I no longer see the management of blocks and plug in
Good to read you again :lol:
