ecowitt Module block
macipbarreda
- Station model: Fine offset
- Software: Cumulus MX
I have installed this Block on my page http://www.meteosantmateu.online/templa ... esktop.php and, as can be seen in the attached image, the intensity of the signal appears in red. I have the ecowitt 2.10 plugin installed, which works perfectly, however, the Block does not reflect it that way. I must say that the sensors that communicate with the ecowitt 1100 are from a Waldbeck Kopernikus station, which looks exactly like the WS 69. Could that be the problem?
- Captura.JPG (42.82 KiB) Viewed 3057 times
- ecowitt block.JPG (23.45 KiB) Viewed 3057 times
Re: ecowitt Module block
In the ecowittModules setup set the second parameter ( main sensor name ) to WH65.
macipbarreda
Once again, thanks for your help.
