Hello everyone and especially Davide,
I switched to https with a domain name on a base built in http.
I have a problem opening my home page, it takes forever to open, more than a minute.
I looked in the developer tool of my Google Chrome search engine and I find errors there.
I don't know how to solve this problem.
I am attaching a copy-paste of the page and its errors.
Please help me to solve this problem
Errors on opening home page
Laglene
- Station model: Davis pro 2
- Software: Weatherlink
- Capture d’écran 2022-01-25 152802.png (516.2 KiB) Viewed 25421 times
Laglene
Re: Errors on opening home page
Bonjour Davide,
Le problème n'est pas résolu, il est inérant uniquement à l'ouverture de ma page sur google. A priori cela fonctionne bien sur des ordinateurs tiers.
Est-ce que vous avez une solution, svp...
Didier
Didier
Your home page is quite 'heavy' ( 17MB ) and complex so its loading time is related to these factors also.
You have a few errors that can be corrected:
- menu 'modele meteo web' has one entry 'Personal weather...' the associated icon https://meteo-galargues.fr/images/pwsicon.png does not exist
- the season icon on the lower left is undefined ( this mod solves the issue )
- the script indexDesktop.php has a small typo ( the attached one solves the issue )
- update the mapsFrance block with the attached one ( changed url of meteociel from http to https )
- worldTime configuration seems missing a configuration ( try repeating the setup ), on the forum there is also an updated block ( fixing a few minor issues, don't know if this may help )
- there are also a few blocks trying to load fonts over http ( http://fonts.googleapis.com/css ) these should be changed to https, need to check
- indexDesktop.zip
- (7.07 KiB) Downloaded 894 times
- mapsFrance_1.1.zip
- (241.8 KiB) Downloaded 850 times
Laglene
Hi Davide, thanks for the answers, I'll try all that and let you know
Have a nice week end
Didier
Didier
Laglene
Hello Davide,
Indeed I improved the home page even if there are still some Iframe errors, I will try to improve soon.
Thanks again for your prompt response.
It was a pleasure
Good end of weekend
Didier
It was a pleasure
Good end of weekend
Didier
The key to a successful web software development service https://mlsdev.com/blog/top-custom-soft ... -companies is a clear understanding of your business goals. The best services will understand your needs, your business, and your customers. They should be able to solve your problems and provide an effective solution. This is the first step in any project. Moreover, software development service should also be able to offer solutions that are customized to fit your business. Once you have an idea of what your business needs, a web software development service provider will start working on it.
