updated interactiveGraph block
Gerrit
Station model: Vantage pro 2 plus
Re: updated interactiveGraph block
Post by Gerrit » Tue Mar 22, 2022 4:52 pm
Good day to you,
My site is https://www.waskolkweer.nl/meteotemplat ... esktop.php
The block is at the bottom of the page as a footer,
Gerrit
Post by alexvanuxem » Tue Mar 22, 2022 6:46 pm
HI David,
thank you for version 7.
i didn't see it untill today. Cool for the calculated solar!
small question: for extra temperature and humidity: does that include indoor. If yes, what's the synthax in the settings?
Tried every possibility. If no: no worries, just nice to have. :-)
Thank you for the great work and site updates!!!
Grtz Alex
Post by davidefa » Tue Mar 22, 2022 7:40 pm
You could have a typo in the 'default graph interval' setting: last30days ( and not 30d )
Post by davidefa » Tue Mar 22, 2022 7:52 pm
alexvanuxem wrote: Tue Mar 22, 2022 6:46 pm HI David,
Grtz Alex
No currently indoor T/H are not included ( but I can add in the next release )
Gerrit
Post by Gerrit » Tue Mar 22, 2022 8:19 pm
You could have a typo in the 'default graph interval' setting: last30days ( and not 30d )/quote]
It was indeed, explains why I saw data in the graph until 2011,
The graphs you referred to on your site look very good, by the way.
Gerrit
tobydude
Software: Weatherdiaplay
Post by tobydude » Thu Mar 24, 2022 9:34 am
Gerrit
Post by Gerrit » Sun Mar 27, 2022 7:38 am
Hello David,
You said Wednesday to have a look at the http://www.fanometeo.it/template/pages/ ... hp?var=SM1 page on your site, I have seen it for a while and now I want to see it again and I only get a white screen and a security message, has something changed on the page, when I want to go to your PM10 page I also get a white screen
Gerrit
Post by davidefa » Sun Mar 27, 2022 10:26 am
It should be ok now ( only a 'small error' in dealing with cached data )
Gerrit
Post by Gerrit » Sun Mar 27, 2022 5:29 pm
It is visible again, thanks
mchd17
Post by mchd17 » Sun Apr 17, 2022 2:24 am
found minor issue
Extra Temp sensors, temp on graph is in C but listed as F, graphs are in C would like to be in F
Post by davidefa » Mon Apr 18, 2022 2:59 pm
ver 11.8
- corrected extra temp sensors not converting to °F
ver 11.9
- corrected extra sensors json data indexing (when selecting out-of-sequence sensors )
- added lightning sensor
- added leaf wetness sensor ( untested )
interactiveGraph_11.9a.zip
(11.46 KiB) Downloaded 1794 times
interactiveGraph_11.8.zip
(10.94 KiB) Downloaded 1731 times
georg
Station model: Davis Pro 2+
Post by georg » Thu May 12, 2022 7:50 am
Hello
I have a problem with the interactive graph.
When opening my page the time on the graph is two hours ahead of the actual time.
(today starts at 2)
Data is correct in the database.
FireShot Capture 097 - Vejret her og nu - https___vejr.arloese.dk_template_indexDesktop.php.png
FireShot Capture 097 - Vejret her og nu - https___vejr.arloese.dk_template_indexDesktop.php.png (95.51 KiB) Viewed 74300 times
If i then select the 3 bars in the upper left corner of the block (menu option)
and select interactive graph it loads correct (and in the correct backgraund color)
FireShot Capture 098 - Vejret her og nu - https___vejr.arloese.dk_template_indexDesktop.php.png
FireShot Capture 098 - Vejret her og nu - https___vejr.arloese.dk_template_indexDesktop.php.png (86.54 KiB) Viewed 74300 times
I can not figure out how to get it to load correctly in the first place (anything to do with high chart, Denmark is 2 hours ahead of UTC i the summer)
Thanks for the updated block, really good work.
georg
Julius
Software: meteobridge
Post by Julius » Tue Aug 30, 2022 9:41 am
davidefa wrote: Mon Apr 18, 2022 2:59 pm ver 11.9
Is there already a method to have 3 Temperature sensors (T,T1,T2) show in one graph?
And how do I designate sensors (T1, T2) to the correct numbers for the colors/names?
Post by davidefa » Thu Sep 01, 2022 9:46 pm
You can use the customGraph block, it can show any sensor on a maximum of 4 different Y axis.
For temp only sensors you need to set the initial parameters ( Y axis 1 parameters )
This is the configuration I use for the first axis ( simply add the third temp sensor in the highlighted fields )
You can also do a 'little of math' if you need ( for example I defined the fourth axis as: T-T4=delta
Post by davidefa » Thu Sep 01, 2022 9:52 pm
@georg
Sorry I missed your post.
There are a lot of unwanted interactions between blocks, ( utc/local time settings are not uniformly handled between blocks ). Need to understand more about this.
Thank you for pointing this out
Julius
Post by Julius » Fri Sep 02, 2022 11:39 pm
davidefa wrote: Thu Sep 01, 2022 9:46 pm You can use the customGraph block, it can show any sensor on a maximum of 4 different Y axis.
Sorry, I don't understand your explanation here.
If I have 3 sensors, T,T1,T2 that I want to show in one graph, how do I enter its values?
See the customGraph in the center here; It's really strange, the time on the horizontal axis is incorrect (it shows the future?).
Also, the naming of the colors under it is in km/h (probably mingles with code from windrose?)..
georg wrote: Thu May 12, 2022 7:50 am Hello
(today starts at 2)
I have exactly the same issues, but with customGraph. Looks like a style naming convention issue interacting with another block (windRose?).
Gary
Software: Meteobridge Nano SD
Post by Gary » Thu Dec 28, 2023 7:19 pm
I really like this latest version of the interactivegraph block, esp as in brings in the extra sensors.
I have a couple of questions, sorry if they got answered before and I didnt notice.....
1: the titles of the graphs display in uppercase, is there a way to change this?
example, from TEMPERATURE to TEMPERATURE or from WIND to WIND
Reason for asking is the other blocks I am using all display the block title in the latter style, so I would like it to be consistent.
2. Some of the graphs have several items displayed
example 1 TEMPERATURE shows: Temperature, Apparent Temperature, Range, Dew Point.
example 2 WIND shows: Wind Speed, Wind Gust, Bearing
I am not so interested in Range and Dew Point in example 1 and Bearing in example 2 displaying on the chart display.
I know I can turn these items "off" or to blank by clicking on them, but I would prefer to have the chart to be without these items showing to start with.
Thank you in advance for your help.
Gary
Post by davidefa » Thu Dec 05, 2024 11:15 pm
Why not adding stupid things to meteotemplate... like sonification ( why not 'listening' to temperature variation )?
ver 12.0
- added sonification ( select a sound and click on play chart )
NOTE
You need also to modify the indexDesktop.php script adding the following line ( near line 211, after similar script tags ):
		<script src="//code.highcharts.com/modules/sonification.js"></script>
interactiveGraph_12.0a.zip
(12.15 KiB) Downloaded 1148 times
Jolumarali
Station model: Vantage Vue
Software: WlIP
Post by Jolumarali » Fri Dec 06, 2024 10:27 am
Thank you, orchestra man
Post by alexvanuxem » Fri Dec 06, 2024 4:37 pm
:D
marcom78
Software: Meteotemplate
Post by marcom78 » Thu Jan 16, 2025 7:55 pm
Hi all
is there any possibility to remove the max-min highlited red area ?
I'm currently using rev 12.0
Marco
