a lot of issues
a lot of issues
an update were I am at.
1: airkink indoor not mapped inside MB, but temp and hum getting across to MT strange?
2: soil moisture 5 and 6 is getting confusded with leaf 1 and 2, same readings
3: got today a new gw1100 with lightning detector, configured it through MB only temp and hum goes to MT, no lightning
but extra temp and hum into MT
4: tried to to configure the ecowitt plugin to incorporate the lightning, much problems,
thank you all for testing, and helping,
many thx to all contributors,
KInd regards
Alex
KInd regards
Alex
Re: a lot of issues
The gw1X00 custom upload can't upload to an https server ( as in your case )
Possible solutions:
- disable the 'https rewrite rule' for the directory template/plugins/ecowitt/report ( or for the whole site )
- on this post on wxforum is explained how to do it on servers ( apache ) using file .htaccess and on IIS server ( microsoft )
- on this post user meteoesine explains how he did
Possible solutions:
Re: a lot of issues
thx, did the .htaccess
got data coming in every minute in csv and json format.
but api is not updated
see screenshots did I miss something?
Re: a lot of issues
hi thx did the adjustment, but no succes.
i found a ecowittlog.txt file in the cache folder it saus : Api error -> Failed to connect to www.sint-katelijne-waver-meteo.be port 443: Connection timed out
can you have a look what it means?
many thanks
many thanks
Re: a lot of issues
You can try the following scripts ( they simulate the calling of the api.php script, only added a browser-like header):
- extract in your template directory
- call them with your browser:
www.sint-katelijne-waver-meteo.be/template/http_api.php
www.sint-katelijne-waver-meteo.be/templ ... ps_api.php
Hopefully should ( one or both ) return something like this:
with no 'time out'
No password provided
Api url -> https://www.sint-katelijne-waver-meteo.be/template/api.php?U=1654783339&P=1020&TIN=21.89&HIN=56&L=0&LD=<=&LBAT=3&Station=GW1100A&FW=V2.0.2
Api result -> 1- Attachments
- http_api.zip
- (1.18 KiB) Downloaded 595 times
Re: a lot of issues
hi,
thx.
both gave a 504 gateway time out error.
tried it with removing the .htaccess and with the firewall off, same result.
the api calling doesn't need my update password?
thx
grtz
thx.
thx
grtz
Re: a lot of issues
Without the 'update password' the api.php script breaks with error 'No password provided' ( if the scripts is executed ), but your call times outalexvanuxem wrote: ↑Thu Jun 09, 2022 5:34 pm hi,
thx.
thx
grtz
I have tested the same scripts on my server:
http://realrunning.netsons.org/template/http_api.php
http://realrunning.netsons.org/template/https_api.php
And they works as expected.
It seems some filter/firewall blocking the call but can't understand what's going on
Are you hosting your domain on a local server or are you using an 'external' hosting provider?
Re: a lot of issues
hi thx for your time
if a pass http://www.sint-katelijne-waver-meteo.b ... &FW=V2.0.2
in the url
i get also no password provided. In both http and https.
uing php 7.4.29
Im using an external provider.
thx again for your help.
I was so looking forward to play with my new toy.
updating with this, hope this helps :
ecowitt calls this
https://www.sint-katelijne-waver-meteo. ... &FW=V2.0.2
and errors
if it calls this
it goes through, when I pass it manually through the url. lightning is saved in the api.php, but I cant do this manually every minute.
. At least some tiny progress.
I hope im helping to find a solution. Can this be tried please,
please share your thoughts.
Thx again David!!
in the url
uing php 7.4.29
ecowitt calls this
and errors
if it calls this
Thx again David!!
Re: a lot of issues
Please try this updated plugin ( it simply replaces the call to api.php via 'curl library', that fails with a timeout on your server, with a 'require', that should work in your case )
- ecowitt_3.0a.zip
- (17.32 KiB) Downloaded 779 times
Re: a lot of issues
THANK YOU SIR!
so great!
appreciate a lot your time and effort!
I will make a contribution to Meteotemplate very soon. As thanks.
Deep respect.
Alex
so great!
Deep respect.
Alex
Re: a lot of issues
Hi Davidefa,
your mod concerning my ecowitt lightning data suddenly stopped working on 22 Jul 22 at 2pm.
before then it was a dream.
I don't have a clue why. Could you possibly help?
Tried a lot of stuff, am at my ends whit. Thank you so much!!
Re: a lot of issues
I see your cache/ecowittLog.txt shows the last data posted by gw1100 is dated 2022-07-22 12:12:15
Check if the gateway is functioning correctly ( verify you can connect to the web interface ), maybe the gateway needs only a reboot or check if the custom upload is still enabled
ecowitt format
post PASSKEY: 5908887D876EC5DD37B2B313B79E0D4B
post stationtype: GW1100A_V2.0.2
post dateutc: 2022-07-22 12:12:15
post tempinf: 80.4
post humidityin: 45
post baromrelin: 30.183
post baromabsin: 30.183
post lightning_time: 1658310356
post lightning_num: 0
post lightning: 20
post wh57batt: 4
post freq: 868M
post model: GW1100A
rename sensor
remap meteotemplate
remap wu
remap awekas
remapping ecowitt <-=
Calling api.php date/time: 2022-07-22 14:18:02
Api call -> {"P":1022.11,"TIN":26.89,"HIN":"45","L":"0","LD":"20","LT":"1658310356","LBAT":"4","Station":"GW1100A","FW":"V2.0.2","U":1658491935}
Exiting api.php date/time: 2022-07-22 14:18:02
Generating log file cache/ecowittLog.txt
ERRORS:
Re: a lot of issues
hi got it back.
after a reboot, version upgrade of the gateway, and filling in the settings back again, thx
alex
alex
- meteoesine
- Station model: Davis Pro2+
- Software: Meteobridge nano
Re: a lot of issues
Ciao,
why in the all reports I find the year 1970 without data?
I checked in phpmyadmin and i don't see any record before 01.01.2014
is there a possibility to remove it?
tnx
tnx
- ScreenShot01122.jpg (69.92 KiB) Viewed 13854 times
Re: a lot of issues
Try executing the following query in phpmyadmin:
and post the result
SELECT max(Tmax), min(Tmin), max(R), max(G), avg(W), min(P), max(P), min(H), max(H), min(D), max(D), min(A), max(A), max(S), max(RR), YEAR(DateTime), MONTH(DateTime)
FROM alldata
GROUP BY YEAR(DateTime), MONTH(DateTime)
ORDER BY DateTime- meteoesine
Re: a lot of issues
found the damn
removed
thnx a lot
thnx a lot
