updated riset block
updated riset block
ver7.1
I have updated the block as it shows the moon transit time incorrectly ( at least in some conditions )
I have also added an option to show the moon position ( along the sun's one )
ver7.2
Reordered moon phases 'by time'
ver7.3
Corrected display of 'lacking phase in the day' ( for example on 1th April 2021 there is no moon rise )
ver7.2
ver7.3
- riset_7.3.zip
- (166.55 KiB) Downloaded 1038 times
- riset_7.2.zip
- (166.35 KiB) Downloaded 964 times
- riset7.1a.zip
- (167.24 KiB) Downloaded 1192 times
- Meteopomezia
- Software: Wview
Re: updated riset block
v7.5 - Aug 24, 2022
- added graph of sun/moon (davidefa)
v7.6 - Aug 29, 2022
- added option to define color of sun and moon graph lines (davidefa)
You can select new or legacy look
v7.6 - Aug 29, 2022
- riset_7.6.zip
- (185.43 KiB) Downloaded 1060 times
- riset_7.5.zip
- (185.24 KiB) Downloaded 1015 times
- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
Hello Davide
Using light and dark mode, the moon line is difficult to see in dark mode, how to change the color of the lines.
thank you
thank you
- riset.jpg (16.92 KiB) Viewed 27505 times
- Jolumarali
- Software: WlIP
perfect
thank you Davide
thank you Davide
weatherbee
I've downloaded latest riset but it doesn't show the sun in updated (new) version. It works in the legacy look.
Not sure why.
You can see at https://www.shermanctweather.org/meteo/indexDesktop.php
Thanks, Tom
Not sure why.
Thanks, Tom
- Jolumarali
- Software: WlIP
Hello Tom
try deleting the entire riset folder on your server and reinstall
Jose Luis
Jose Luis
Hi Tom, you may try this version
v7.7 - Aug 30, 2022
- set TurboOption ( for highcharts data as objects > 1000 points )
- now both sun and moon icons move following the cursor
v7.7 - Aug 30, 2022
- riset_7.7.zip
- (185.5 KiB) Downloaded 1015 times
- Jolumarali
- Software: WlIP
thank you Davide
weatherbee
Meteo Heijningen
- Station model: Ecowitt Wittboy GM2001
I switched over to PHP8.1 (had to do this before the end of this week) All seems to work well after updating. Doing tests now and having problem with the riset block, After updating from 7.3 to 7.7 still getting a warning:
Warning: Undefined variable $showMoonPosition in /customers/e/8/4/famgladdines.nl/httpd.www/meteotemplate/template/homepage/blocks/riset/settings.php on line 8
Also found out that the block aurora is not working on 8.1
Eddy
Eddy
Meteo Heijningen
Hi all,
The problem with the riset block solved.
The cause of the warning was a $ too many in the code:
<?php
// riset settings file
// Version: 7.3
// Created: 2022-11-23 12:26:15
$autoOpenRiset = false;
$showStatPosition = true;
$$showMoonPosition = true;
After removing the second $ sign, so its now $showMoonPosition = true;, it worked again.
For the aurora block still need some help I guess but I will give it a try.
Cheers
Eddy
<?php
// Version: 7.3
Cheers
Eddy
ver 7.8
- removed warnings/deprecation for php 8 ( a few seconds difference, respect to previous version, in times )
- corrected time scale and timezone in graph
- added option to colorize sun graph
- corrections for areas above polar circles
Stock meteotemplate 18.0/19.0 function.php script did not work for me on php 8.2, the attached one fixes it, uncompress in your scripts folder
- functions_19.2.zip
- (9.66 KiB) Downloaded 936 times
- riset_7.8.zip
- (200.98 KiB) Downloaded 988 times
thx! nice work!
I did not need to update the functions.php, it worked,
it only had influence on the stock version?
i did it anyway, no influence on previous version (header, moon,...)?
(i have a backup just in case).
ps: until now your rain api mod works good! thank you man!!
grtz
Alex
grtz
Alex
- MeteoElMasnou
