updated riset block
updated riset block
Post by davidefa » Sun Mar 21, 2021 11:23 am
ver7.1
I have updated the block as it shows the moon transit time incorrectly ( at least in some conditions )
I have also added an option to show the moon position ( along the sun's one )
ver7.2
Reordered moon phases 'by time'
ver7.3
Corrected display of 'lacking phase in the day' ( for example on 1th April 2021 there is no moon rise )
riset_7.3.zip
(166.55 KiB) Downloaded 1038 times
riset_7.2.zip
(166.35 KiB) Downloaded 964 times
riset7.1a.zip
(167.24 KiB) Downloaded 1192 times
Meteopomezia
Software: Wview
Re: updated riset block
Post by Meteopomezia » Sun Mar 21, 2021 12:10 pm
Grazie mille interessante aggiornato il blocco :D
Semtex
Station model: Davis Vantage Pro Plus 2
Post by Semtex » Tue Mar 23, 2021 11:21 pm
Good job
Post by davidefa » Fri Aug 26, 2022 9:41 pm
v7.5 - Aug 24, 2022
- added graph of sun/moon (davidefa)
v7.6 - Aug 29, 2022
- added option to define color of sun and moon graph lines (davidefa)
You can select new or legacy look
riset_7.6.zip
(185.43 KiB) Downloaded 1060 times
riset_7.5.zip
(185.24 KiB) Downloaded 1014 times
Jolumarali
Station model: Vantage Vue
Software: WlIP
Post by Jolumarali » Mon Aug 29, 2022 6:25 am
Hello Davide
Using light and dark mode, the moon line is difficult to see in dark mode, how to change the color of the lines.
thank you
Post by davidefa » Mon Aug 29, 2022 9:47 pm
Updated previous post
Jolumarali
Software: WlIP
Post by Jolumarali » Tue Aug 30, 2022 6:23 am
perfect
thank you Davide
weatherbee
Post by weatherbee » Tue Aug 30, 2022 2:38 pm
I've downloaded latest riset but it doesn't show the sun in updated (new) version. It works in the legacy look.
Not sure why.
You can see at https://www.shermanctweather.org/meteo/indexDesktop.php
Thanks, Tom
Jolumarali
Software: WlIP
Post by Jolumarali » Tue Aug 30, 2022 2:42 pm
Hello Tom
try deleting the entire riset folder on your server and reinstall
Jose Luis
Post by davidefa » Tue Aug 30, 2022 4:02 pm
Hi Tom, you may try this version
v7.7 - Aug 30, 2022
- set TurboOption ( for highcharts data as objects > 1000 points )
- now both sun and moon icons move following the cursor
riset_7.7.zip
(185.5 KiB) Downloaded 1015 times
Jolumarali
Software: WlIP
Post by Jolumarali » Tue Aug 30, 2022 5:10 pm
thank you Davide
weatherbee
Post by weatherbee » Tue Aug 30, 2022 11:36 pm
Thank you davidefa.
It works now.
Thanks again,
Meteo Heijningen
Station model: Ecowitt Wittboy GM2001
Post by Meteo Heijningen » Wed Nov 23, 2022 11:40 am
I switched over to PHP8.1 (had to do this before the end of this week) All seems to work well after updating. Doing tests now and having problem with the riset block, After updating from 7.3 to 7.7 still getting a warning:
Warning: Undefined variable $showMoonPosition in /customers/e/8/4/famgladdines.nl/httpd.www/meteotemplate/template/homepage/blocks/riset/settings.php on line 8
Also found out that the block aurora is not working on 8.1
Eddy
Meteo Heijningen
Post by Meteo Heijningen » Wed Nov 23, 2022 12:31 pm
Hi all,
The problem with the riset block solved.
The cause of the warning was a $ too many in the code:
<?php
// riset settings file
// Version: 7.3
// Created: 2022-11-23 12:26:15
$autoOpenRiset = false;
$showStatPosition = true;
$$showMoonPosition = true;
After removing the second $ sign, so its now $showMoonPosition = true;, it worked again.
For the aurora block still need some help I guess but I will give it a try.
Cheers
Eddy
Post by davidefa » Thu Nov 30, 2023 10:32 am
ver 7.8
- removed warnings/deprecation for php 8 ( a few seconds difference, respect to previous version, in times )
- corrected time scale and timezone in graph
- added option to colorize sun graph
- corrections for areas above polar circles
Stock meteotemplate 18.0/19.0 function.php script did not work for me on php 8.2, the attached one fixes it, uncompress in your scripts folder
functions_19.2.zip
(9.66 KiB) Downloaded 936 times
riset_7.8.zip
(200.98 KiB) Downloaded 988 times
Post by alexvanuxem » Thu Nov 30, 2023 5:33 pm
thx! nice work!
I did not need to update the functions.php, it worked,
it only had influence on the stock version?
i did it anyway, no influence on previous version (header, moon,...)?
(i have a backup just in case).
ps: until now your rain api mod works good! thank you man!!
grtz
Alex
MeteoElMasnou
Post by MeteoElMasnou » Sat Dec 02, 2023 4:04 pm
thx! Davide.
