Offline problems
2mPhoto
Station model: Oregon
Offline problems
Post by 2mPhoto » Tue Oct 25, 2022 8:36 pm
Hi everyone.
I recently changed my weather station. Without too much difficulty I updated the upload of the data online. But while last night it went offline at times during the night, today it worked all day and then crashed at 7pm and reactivated later, without logic. Has anyone ever had these problems? I use an ecowitt with itroom as a site.
lemimi
Re: Offline problems
Post by lemimi » Wed Oct 26, 2022 5:53 am
I too have the same problem for 5 days with Ecowitt.
A few cuts at the start, and yesterday, more than 10 hours downtime!
View here: http://www.template.lemimi.fr/indexFull ... tionStatus
I reinstalled MT: same thing.
Good day to all... Michel
Post by davidefa » Wed Nov 09, 2022 11:52 pm
To check the ecowittNet functionality you can try executing in your browser ( insert your update password ):
http://www.template.lemimi.fr/load/cron.php?password=YOURPASSWORD&errors
For the netatmo plugin try executing in your browser ( insert your update password ):
http://www.template.lemimi.fr/plugins/netAtmo/update/update.php?pass=YOURPASSWORD&errors
Check if there are any error/warning
lemimi
Post by lemimi » Thu Nov 10, 2022 7:42 am
Hello @davidefa,
Here is the error output with EcowittNet : http://www.template.lemimi.fr/load/cron ... ORD&errors
oad/crons
Current date/time: 2022-11-10 08:14:52
sensor T=[outdoor][temperature][value]=6.6111111111111
sensor U=[outdoor][temperature][time]=1668064486
sensor H=[outdoor][humidity][value]=94
sensor TIN=[indoor][temperature][value]=16.611111111111
sensor HIN=[indoor][humidity][value]=63
sensor S=[solar_and_uvi][solar][value]=8.6
sensor UV=[solar_and_uvi][uvi][value]=0
sensor RR=[rainfall][rain_rate][value]=0
sensor R=[rainfall][daily][value]=0
sensor W=[wind][wind_speed][value]=3.5405568
sensor G=[wind][wind_gust][value]=5.4717696
sensor B=[wind][wind_direction][value]=185
sensor P=[pressure][relative][value]=1024.38240025
Calling api.php date/time: 2022-11-10 08:14:52
Notice: Undefined variable: extraQueryParams in /home/lemimifr/template.lemimi.fr/api.php on line 1763
Success
Exiting api.php date/time: 2022-11-10 08:14:52
Loaded CRON: /home/lemimifr/template.lemimi.fr/load/crons/updateEcowittNet.php
and with Ecowitt : http://www.template.lemimi.fr/plugins/e ... ORD&errors
ecowitt format
Notice: Undefined index: PASSKEY in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 252
Notice: Undefined variable: ecowittNSensors in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 264
Notice: Undefined variable: ecowittNSensors in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 401
Notice: Undefined variable: ecowittNSensors in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 431
Notice: Undefined offset: 1 in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 477
Notice: Undefined offset: 1 in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 490
Notice: Undefined offset: 1 in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 491
Notice: Undefined index: in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 491
Notice: Undefined offset: 1 in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 528
Notice: Undefined offset: 1 in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 553
Calling api.php date/time: 2022-11-10 08:15:33
Success
Exiting api.php date/time: 2022-11-10 08:15:33
Success. Update done
and with netAtmo : http://template.lemimi.fr/plugins/netAt ... ORD&errors
Notice: Undefined variable: extraQueryParams in /home/lemimifr/template.lemimi.fr/api.php on line 1331
Success
Thank you for your help and have a nice day...Michel
lemimi
Post by lemimi » Thu Nov 10, 2022 12:08 pm
I send, via the cron task, since 10:30 am (by adding &errors to the link):
curl http://www.template.lemimi.fr/load/cron ... ORD&errors
Every 5 minutes and it works! ... for the moment :-)
It's 5:35 p.m. and it's still working!
Post by andyk1 » Thu Nov 17, 2022 7:32 pm
@ David. When I run the same command using your php 8.1 updates I get a blank white screen https://www.nicomaparkwx.com/load/cron. ... RD2&errors & http://www.nicomaparkwx.com/plugins/eco ... RD2&errors
Any ideas?
