Hi everyone.
I recently changed my weather station. Without too much difficulty I updated the upload of the data online. But while last night it went offline at times during the night, today it worked all day and then crashed at 7pm and reactivated later, without logic. Has anyone ever had these problems? I use an ecowitt with itroom as a site.
Offline problems
- lemimi
Re: Offline problems
I too have the same problem for 5 days with Ecowitt.
A few cuts at the start, and yesterday, more than 10 hours downtime!
View here: http://www.template.lemimi.fr/indexFull ... tionStatus
I reinstalled MT: same thing.
Good day to all... Michel
To check the ecowittNet functionality you can try executing in your browser ( insert your update password ):
For the netatmo plugin try executing in your browser ( insert your update password ):
Check if there are any error/warning
http://www.template.lemimi.fr/load/cron.php?password=YOURPASSWORD&errorsCode: Select all
http://www.template.lemimi.fr/plugins/netAtmo/update/update.php?pass=YOURPASSWORD&errors- lemimi
Hello @davidefa,
Here is the error output with EcowittNet : http://www.template.lemimi.fr/load/cron ... ORD&errors
and with Ecowitt : http://www.template.lemimi.fr/plugins/e ... ORD&errorsoad/crons
Current date/time: 2022-11-10 08:14:52
sensor T=[outdoor][temperature][value]=6.6111111111111
sensor U=[outdoor][temperature][time]=1668064486
sensor H=[outdoor][humidity][value]=94
sensor TIN=[indoor][temperature][value]=16.611111111111
sensor HIN=[indoor][humidity][value]=63
sensor S=[solar_and_uvi][solar][value]=8.6
sensor UV=[solar_and_uvi][uvi][value]=0
sensor RR=[rainfall][rain_rate][value]=0
sensor R=[rainfall][daily][value]=0
sensor W=[wind][wind_speed][value]=3.5405568
sensor G=[wind][wind_gust][value]=5.4717696
sensor B=[wind][wind_direction][value]=185
sensor P=[pressure][relative][value]=1024.38240025
Calling api.php date/time: 2022-11-10 08:14:52
Notice: Undefined variable: extraQueryParams in /home/lemimifr/template.lemimi.fr/api.php on line 1763
Success
Exiting api.php date/time: 2022-11-10 08:14:52
Loaded CRON: /home/lemimifr/template.lemimi.fr/load/crons/updateEcowittNet.php
and with netAtmo : http://template.lemimi.fr/plugins/netAt ... ORD&errorsecowitt format
Notice: Undefined index: PASSKEY in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 252
Notice: Undefined variable: ecowittNSensors in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 264
Notice: Undefined variable: ecowittNSensors in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 401
Notice: Undefined variable: ecowittNSensors in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 431
Notice: Undefined offset: 1 in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 477
Notice: Undefined offset: 1 in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 490
Notice: Undefined offset: 1 in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 491
Notice: Undefined index: in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 491
Notice: Undefined offset: 1 in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 528
Notice: Undefined offset: 1 in /home/lemimifr/template.lemimi.fr/plugins/ecowitt/report/index.php on line 553
Calling api.php date/time: 2022-11-10 08:15:33
Success
Exiting api.php date/time: 2022-11-10 08:15:33
Success. Update done
Thank you for your help and have a nice day...MichelNotice: Undefined variable: extraQueryParams in /home/lemimifr/template.lemimi.fr/api.php on line 1331
Success
- lemimi
I send, via the cron task, since 10:30 am (by adding &errors to the link):
curl http://www.template.lemimi.fr/load/cron ... ORD&errors
Every 5 minutes and it works! ... for the moment
It's 5:35 p.m. and it's still working!
- Station model: Ecowitt WS90
@ David. When I run the same command using your php 8.1 updates I get a blank white screen https://www.nicomaparkwx.com/load/cron. ... RD2&errors & http://www.nicomaparkwx.com/plugins/eco ... RD2&errors
Any ideas?
Any ideas?
