partnerStation block
Post by meteoesine » Wed Dec 28, 2022 7:52 am
Hi and season greetings
is there anyone who could fix this block for php 8.1?
many thanks in advance
Re: partnerStation block
Post by davidefa » Sun Jan 29, 2023 12:15 am
Ver 3.1 is php 8.1 compatible and contains wu api v2 mods ( this should be the version by MonyMony )
partnerStations_3.1.zip
(240.38 KiB) Downloaded 460 times
Post by meteoesine » Sun Jan 29, 2023 8:59 am
thanks a lot
but if i need to add more stations, what is the correct syntax?
so it doesn't work...
$wuStations[] = array(
"IJIHOMOR14",
"Jachym, Meteotemplate",
"WH1080",
"Brno <br>(Moravie du Sud)","esine <br>(Sud)",
"cz","cz",
"http://www.meteotemplate.com/template/indexDesktop.php"
"IESINE4",
"john, test",
"WH1080",
"esine <br>(Sud)",
"cz",
Post by davidefa » Sun Jan 29, 2023 9:13 am
I have the following in settings2.php:
						"IFANO20",
						"Davidefa, Meteotemplate",
						"WH1080",
						"Fano",
						"it",
						"http://www.fanometeo.it/template"
						"IJIHOMOR14",
						"WH1080",
						"Brno",
						"cz",
						"http://www.meteotemplate.com"
						"IPRAGUE580",
						"Petr",
						"netAtmo",
						"Prague",
						"cz",
						"http://www.meteopage.com/prague"
settings2.zip
(680 Bytes) Downloaded 640 times
Jolumarali
Station model: Vantage Vue
Software: WlIP
Post by Jolumarali » Sun Jan 29, 2023 11:05 am
You have to clear the cache after each modification.
Glad to see you again Davide :)
