Hi and season greetings
is there anyone who could fix this block for php 8.1?
many thanks in advance
partnerStation block
- meteoesine
- Station model: Davis Pro2+
- Software: Meteobridge nano
Re: partnerStation block
Ver 3.1 is php 8.1 compatible and contains wu api v2 mods ( this should be the version by MonyMony )
- partnerStations_3.1.zip
- (240.38 KiB) Downloaded 460 times
- meteoesine
thanks a lot
but if i need to add more stations, what is the correct syntax?
so it doesn't work...
$wuStations[] = array(
"IJIHOMOR14",
"Jachym, Meteotemplate",
"WH1080",
"Brno <br>(Moravie du Sud)","esine <br>(Sud)",
"cz","cz",
"http://www.meteotemplate.com/template/indexDesktop.php"
"IESINE4",
"john, test",
"WH1080",
"esine <br>(Sud)",
"cz",
"IJIHOMOR14",
"WH1080",
"cz","cz",
"IESINE4",
"john, test",
"WH1080",
"esine <br>(Sud)",
"cz",
I have the following in settings2.php:
"IFANO20",
"Davidefa, Meteotemplate",
"WH1080",
"Fano",
"it",
"http://www.fanometeo.it/template"
"IJIHOMOR14",
"WH1080",
"Brno",
"cz",
"http://www.meteotemplate.com"
"IPRAGUE580",
"Petr",
"netAtmo",
"Prague",
"cz",
"http://www.meteopage.com/prague"
- settings2.zip
- (680 Bytes) Downloaded 640 times
- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
You have to clear the cache after each modification.
Glad to see you again Davide
