Hi everone,
I'm still working on a new version of my weatherstation site. Everything seems to work fine, but het climat map won't load. Error message: Oops! Something went wrong loading this page. Google Maps is not loaded .... See Javascript console .. etc.
I opened the Javascript console and noticed that it uses an old API Key I deleted on the Google Maps Platform
Here's wat I did:
1. Deleted an old API Key on the Google Maps Platform
2. Restored my billing information on the same platform
3. Configured the (right) settings to use the key (see screenshot)
4. I changed the key in file GoogleMapsKey.txt (install folder)
5. And still the climate map page uses the old Google Maps API key
I wonder if it is right to execute the "setup.php" again, but I think this will change the configuration of the site completely. So, I'm asking for advice for this issue.
Thanks a lot in advance.
Climate map not loading
greenstreet
MM0ZIF
- Station model: Ecowitt 1xxx
Re: Climate map not loading
I have exactly the same issues here, I wonder if Google changed something
The google api key is saved in the config.php file ( see $googleMapsAPIKey near line 206 ).
To change it, you can rerun the meteotemplate main setup again, or if you fear to mess with something, you can edit the config.php file directly ( in this second case make a backup of the file, as messing with it may 'block' your entire site, I edit it directly quite often though )
greenstreet
Hi Davidefa,
Thanks for your advice. It finally works!
Best regards and thank you again,
Luc
Luc
Julius
- Software: meteobridge
So, what did you actually do to make it work? For me this is still "loading" and not showing anything..
Extract this script in pages/climate directory ( will overwrite the existing climate_json.php script ), it should fix your issue.
- climate_json.zip
- (781 Bytes) Downloaded 566 times
greenstreet
Thanks to all of you!
It works fine now, the map is loading again!
Thank you again!
Thank you again!
