snow
snow
Post by meteoesine » Thu Nov 30, 2023 7:19 am
I noticed that if there are no snow accumulations in a season, in my case last season 2022-23 (leaving the values of all months at zero), the reportSeason.php and allSeason.php do not display correctly (they only display in part) the reports; while if you add even just a 0.001 to any day it is displayed correctly (but recording a non-existent snow day)
Is this just my problem or are others experiencing this problem too?
thanks to whoever will solve it
good snow everyone
Screenshot - 30_11_2023 , 08_07_51.jpg (161.56 KiB) Viewed 36173 times
Screenshot - 30_11_2023 , 08_06_19.jpg (207.86 KiB) Viewed 36173 times
Re: snow
Post by meteoesine » Sat Dec 09, 2023 3:34 pm
Remind for above, tnx
Re: snow
Post by davidefa » Sat Dec 09, 2023 10:44 pm
This is a 'quick and dirty fix' of the plugin for php 8.x compatibility ( you need also to update the scripts/functions.php with the attached one, it is compatible with the one you posted a few days ago, it is compatible with meteotemplate 18.0 and 19.0 )
In the main setup of meteotemplate, in place of the darksky ( r.i.p. 🪦 ) api key insert the openweathermap api key ( which is used by the current block ) and should replace darksky forecasts ( the api is similar ).
functions_20231209a.zip
(9.66 KiB) Downloaded 1061 times
snow_4.2.zip
(156.02 KiB) Downloaded 1041 times
Re: snow
Post by meteoesine » Sun Dec 10, 2023 7:25 am
grazie Davide, ma il problema rimane anche con gli ultimi aggiornamenti.
https://meteoesine.it/template/plugins/ ... eports.php
guarda la stagione 2022-2023 (dove è tutto a 0 perchè non ha mai nevicato) il report viene visualizzato solo a metà rispetto alle altre stagioni che hanno registrato almeno 1 giorno di neve - si interrompe alla fine delle 'statistiche mensili';
Inoltre, ora, nel riepilogo generale: https://meteoesine.it/template/plugins/ ... Season.php
nel confronto inverni, le colonne delle stagioni sono visualizzate a casaccio: 2014/2015 - 2013/2014 - 2015/2016 - 2014/2015 ... e poi la tabella si allunga al di fuori della videata.
grazie
Screenshot - 10_12_2023 , 08_21_26.jpg (248.86 KiB) Viewed 36131 times
Re: snow
Post by davidefa » Sun Dec 10, 2023 1:01 pm
Ok, You sould post/pm me your snow mysql table ( use phpmyadmin to make a backup ).
The allSeason.php script has a few problems ( and I can't replicate it with my data ):
- in 'confronto inverni' every column is repeated twice
- the row 'giorni consecutivi...' for season 13/14 and 22/23 ( when no snow was recorded ) is wrong and reports all days
Re: snow
Post by meteoesine » Sun Dec 17, 2023 2:47 pm
@davidefa hai ricevuto la mia tabella snow?
Re: snow
Post by davidefa » Sun Dec 17, 2023 3:46 pm
Yes, I already uploaded plugin ver 4.3 and it was working... but now I see plugin ver 4.1.
I reuploaded ver 4.3 and it is working again now ( the zipped plugin is in the plugins directory ).
Does it work correctly now?
Re: snow
Post by meteoesine » Sun Dec 17, 2023 4:36 pm
tnx Davide,
allSeason.php is OK but snowReports.php still not:
shows a string of errors above the header and again the report stops at the monthly statistics (season 2022-23 when everything is at 0)
Screenshot - 17_12_2023 , 17_25_18.jpg (163.91 KiB) Viewed 36098 times
Screenshot - 30_11_2023 , 08_07_51.jpg (161.56 KiB) Viewed 36098 times
Re: snow
Post by davidefa » Sun Dec 17, 2023 10:14 pm
Ok, it should work now.
Graph 3,4,5 ( on reportSeason ) are now shown too.
Re: snow
Post by meteoesine » Mon Dec 18, 2023 6:03 am
Thanks you very much Davide, great job as always
I take this opportunity to wish you and the all the forum's users Merry Christmas.
The fixed plugin is attached
snow_4.3.zip
(157.43 KiB) Downloaded 1046 times
